Piet30 reageerde in het onderwerp Martijns Oldtimer 1968, Oldtimer 1971, Ciao PX en Superbravo in het forum Projecten 17 jaar geleden
I like your Oldtimer Ciao kickblok rebuild.:thumb
It looks similar to mine 1971er Kick Ciao
Great work, interested to see the whole Oldtimer running;)
Piet30 reageerde in het onderwerp 2F4OV 47,6 *XSH Race* HPI Simo Ciao in het forum Projecten 17 jaar geleden
no idea if dat zo hoort, but it looks great=)
Piet30 reageerde in het onderwerp Piet's Off Road Bravo in het forum Projecten 17 jaar geleden
hahaha, that’s right. Ducati Senna looks great.:bier
standing still is regression:D
yeah, you also like to drive off road with your Bravo I see. Yes, it has the same color, funny.=) Also the wheelen looks the same.:thumb
What engine do you use in it?
hahaha, yes I like to try off road. Your dampers looking good. Are they in good working condition?8)
Piet30 reageerde in het onderwerp Piet's SimoPinasco Brommer in het forum Projecten 17 jaar geleden
haha, yes got your ignition but didn’t meet your brother.:D Maybe was to early for him.
jeah, got a nice exhaust:rules
Piet30 reageerde in het onderwerp Oil seal ring Malossi Kick Reedvalve in het forum General questions 17 jaar geleden
yes, 5mm is the thickness.
Thanks,Ralf
Piet30 reageerde in het onderwerp How to: complete motor tunen voor 43DR evo in het forum Oude topics 17 jaar, 1 maand geleden
thanks Hans for translating it into Dutch.:thumb
to make the engine finish here the last chapter.
Grind the cylinder head:
a gab of 1mm to 1,2mm between piston at OT and cylinder head should be ok.
Measured the ori cylinder head
it’s 1,65mm at the head
to grind the head you should fix a sheet of 60er grinding paper on a glas…[Lees meer]
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 17 jaar, 2 maanden geleden
the view from your workbench is fantastic=)
hehe, you crazy man.:D Are you working in your living room again:thumb
Looks that your classic Bravo will get wings. Like to see the filmpje:bier
Piet30 reageerde in het onderwerp Piet30 VCT09 Kick start brommer in het forum Projecten 17 jaar, 2 maanden geleden
Thanks for your comments, moves down like oil (as we say):bier
@ PoliniCitta: yes I thought so, the RPM’s are raising higher and higher the longer I drive. At the moment I’m driving with a 10,5er gear ratio 65mm clutch bell and 80mm pully. I think I will change the gearbox to 8,5er ratio. Don’t need to buy a new v-belt:D
@ Mike: the Kick…[Lees meer]
Piet30 reageerde in het onderwerp Polini top one on 70 ciao, in het forum General questions 17 jaar, 2 maanden geleden
No I havn’t dealed with this specific guys from Motorluppino but with another Switzerland shop called Cycletech. The shipping cost and paying customs was very high.
And your shippment cost of about 22 Euro from Netherland to UK is less than I payed from Switzerland to Germany.8)Due to that I also prefer to buy from Netherland, JMPB. They have…[Lees meer]
in Switzerland you can still order the Proma CC;)
http://www.motoriluppino.ch/Shop.php
[url=http://www.webmart.de/wmshop.cfm?ID=54281&CID=82142&SubDo=open]klick here Proma CC[/url]
greets,Ralf
I would say no, don’t fit.
As I measure on my old Ciao with 19″ wheels there is only 6,5 to 7 cm space between head and fendor. The Polini Top One needs 7 to 7,5 cm space.
I drive a Proma CC, that exhaust fits;)
greets,Ralf
Piet30 reageerde in het onderwerp Simo side inlet + Pinasco in het forum Pub talk 17 jaar, 3 maanden geleden
no, it is not expensive.
bought the side inlet carter half and the carburetor at Cycletech (Switzerland) when they had their 20% price reduction action for around 150,- Euro.
The big carter was a scrap carter for zero=)
Enlarging cylinder sit for 46mm Pinasco in the great carter half 20,- Euro( if I remember right)
And the Pinasco…[Lees meer]
wuhaha, yes it is a cp engine but the chainsaw chip from Nuckelchen could be an option.;)
In the meantime I have made some short videos
[url=http://de.youtube.com/watch?v=d2vD-cYEpX0]filmpje1[/url]
[url=http://de.youtube.com/watch?v=nd30W-RqwH4]filmpje2[/url]
[url=http://de.youtube.com/watch?v=PAiWGI07zA4]filmpje3[/url]
At the…[Lees meer]
Piet30 reageerde in het onderwerp a chainsaw-brain on a vespa ciao in het forum Kneipechats 17 jaar, 3 maanden geleden
coole Sache:thumb
Piet30 reageerde in het onderwerp Brom / Snor Kruk in het forum General questions 17 jaar, 3 maanden geleden
jau, understood, it is like I thought.
Thanks again. I will keep it in my mind now.:thumb
Piet30 reageerde in het onderwerp Side stand in combi Kick Block in het forum General questions 17 jaar, 3 maanden geleden
so, today the sun was shining and I did some modifications on my side stand;)
First cutted the tube by some mm from the backside
Due to that the side stand comes closer to the frame by the distance of the cutted ring
Then put the cutted ring from the other side on the pedal arm to get the same length like before
Put kick…[Lees meer]
:: Piet30
