sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 4 maanden geleden
It’s been a while since last, the raw material for the carter have arrived and I will bring it to mill-man tomorrow. However we’ll probably not mill anything tomorrow he will do it on his own, hopefully during January.Meanwhile, I’ll be CAD’ing up a hub for the front rim, to fit a disc brake, just need to get to the workshop and make some…[Lees meer]
sx3-swe reageerde in het onderwerp DBR Engine 3-Taps in het forum Carters 7 jaar, 4 maanden geleden
I agree with zevenenergie, it’s not fair to compare cast to CNC even though they both have pros and cons.
In the CNC case you need larger amount of material which mostly are dead milled and useless, while casting you only consume the correct amount of material. So material cost is much higher.
But as with everything else, the more you buy the…[Lees meer] -
sx3-swe reageerde in het onderwerp What crankshaft is this? in het forum General questions 7 jaar, 4 maanden geleden
Naa nothing for me, was just curious because I’ve never seen one of theese before. ๐
sx3-swe heeft het onderwerp What crankshaft is this? aangemaakt in het forum General questions 7 jaar, 4 maanden geleden
Found this on the Swedish version of Ebay..
Never seen this brand before?https://www.tradera.com/item/344400/333595033/piaggio-ciao-vevparti
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 6 maanden geleden
Then you’ll have to get on a plane here to Sweden and be a Slave for the machine operator for 20+ works hours. ๐ Should I reserve 007 for you then? ๐
I wish that I had the possibility to offer this crankcase for other people, unfortunatly my friend only machine for a hobby and not for the money. He machine in change for help with something he…[Lees meer]
Thanks guys!
If I let a company machine this for me then this would be aprox theese prices:
1 piece: 964โฌ
5 piece: 380โฌ
10 piece: 300โฌIn my case me and my friend trade services.. he owes me 50 hours on the machine because of work I have done for him so I’ll only need to buy the raw material which is like 240โฌ worth of aluminium. (Fu*kin…[Lees meer]
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 7 maanden geleden
Santa claus came early this year. ๐
I have realized that the reed valve needs more room, so I redesigned the inlet. Instead of covering the crank it’s a more Malossi C-One inspired reedintake. Some other minor improvements done, such as tolerance for bearings and oil seals.. And oh.. A slightly different design.. Noone will notice the…[Lees meer]
I hear you, but if I inclinde the bracket, I must also raise it.. If I raise it I will get bigger volume in the carter = less crank case compression.. I think I will go with this design.. One day I will hopefully test it on Dyno, then I’ll eloborate with both intake rubbers but also VL18 vs Vforce3 membraan.. I think the VL18 is a good choice…[Lees meer]
@zevenenergie, No I’m using Autodesk Inventor.. But it’s basically the same thing. ๐
@jaffabaffa, yes that is indeed a chapter of its own, there will be pretty decent amount of power packed into the frame so there will be needย for reinforcements anyway.
The carter inclines 20 degree where the membraan goes. The AM6 intake rubber has 40 degree…[Lees meer]
Yes, It’s too much angle on the carb… Dellorto says max 30 degrees, but 0-20 is preferred!
This manifold is a TPR for AM6.. TPR has one for horizontal where the rubber is more angled.. I have ordered this rubber and hopefully it will be perfect and it doesn’t incline negative.I will fit the motor in the Ciao before I mill the final carter, but…[Lees meer]
sx3-swe reageerde in het onderwerp Tiesman perso in het forum Projecten 7 jaar, 7 maanden geleden
Ahh okey.. It’s handmade in Italy? No where to buy the exhaust I guess?
On a Ciao ๐
Nice! ๐ What exhaust is that? Jollymoto?
Cylinder have been ordered, it will be 2 weeks before I get it… It will be tuned before it leaves the shop ๐ฎ ๐ฎ
Anyway, I started to test fit some parts, so far so good! There are 1 thing I noticed so far and it’s the angle of carburator which is too steep.. This intake is a Top performance for AM6.. The rubber for the same type intake but for…[Lees meer]
@Martino, Thanks.. ๐
@zevenenergie, Next step is to testfit crankshaft, membraan, intake, carb ignition and so on, to make sure there are no collisions (collisions in both parts and my brain)..
The step after that is to get me a cylinderkit so that I can make sure the cylinder fits with that thing pointing out in front of the membraan and also…[Lees meer]
Me too, can’t wait to get my hands on theese ๐
Goal, I don’t know.. I like to build stuff and thats probably the main goal.. Hell, I remember when I was 15 and immortal (atleast I thought i was), even then a 43mm+13mm felt like a death wish on a ciao when peaking speed :D, and now 18 years later I don’t think this ahve changed, It might even have gotten worse ๐
I have been looking at Roost,…[Lees meer]
sx3-swe reageerde in het onderwerp Axle-to-axle difference between Ciao and SI in het forum General questions 7 jaar, 7 maanden geleden
No one have the answer? ๐
@Martino: Hehe, so you say I should have gone off with Malossi instead? ๐ I really liked the modularity of the S6R/T, and it looked sexy with the CNC head instead of the more common cast aluminum and by the round shape I imagined that it will make the fittinnside the Ciao easier.
@Ritze, yea I’ve read some on internet regarding pits and cavities…[Lees meer]
sx3-swe heeft het onderwerp Axle-to-axle difference between Ciao and SI aangemaakt in het forum General questions 7 jaar, 7 maanden geleden
Hello,
Anyone who owns both a standard Ciao P AND a SI who can help me with measurment?
I’d like to know the measurment between Crankshaft axle and variomatic axle.
Ciao Snaar with 100mm pulley = 975mm
SI snaar with 100mm pulley = 11501150-975/2 = 87,5mm
Is it correct that SI length between axles are 87,5mm longar than Ciao P?
