Axle-to-axle difference between Ciao and SI
Home Forums English General questions Axle-to-axle difference between Ciao and SI
  • #778980
    sx3-swe
      Hello,
      Anyone who owns both a standard Ciao P AND a SI who can help me with measurment?
      I’d like to know the measurment between Crankshaft axle and variomatic axle.
      Ciao Snaar with 100mm pulley = 975mm
      SI snaar with 100mm pulley = 1150
      1150-975/2 = 87,5mm
      Is it correct that SI length between axles are 87,5mm longar than Ciao P?
      #779141
      sx3-swe
        No one have the answer? 🙂
        #779144
          You have to know the units you are describing are the belt lengths. So you cannot say the length will be 87mm more.
          I can measure the length from crankshaft to gearbox for you. But I don’t own a Si.
          Seru.ch
            The axle-to-axle difference at Si is 470mm.
            #782277
            sx3-swe
              Anyone have the Axle-to-axle for Ciao? tried to measure my frame and the Cadded engine and if I’m not mistaken, axle-to-axle on Ciao should be 375mm.
              That would result in that SI is 95mm longer than Ciao P, if Seru.ch measurments on SI are correct.
              #782338
              AA-T
                How accurate do these measurements need to be? And just because I’m curious, why do you need to know this?
                Unfortunately I’m unable to measure it for you. But looking at this, and performing the same calculation you did the outcome varies between 86.5 (pulley 60/65) and 97.5 (pulley 95).
                The difference in the angle of the belt, caused by the difference in the distance of the axles explains why the outcomes vary. So it’s not an exact science.
                If the measurements need to be very accurate it’s also very important to know in what position the engine is for both the Ciao and Si. Because you can move the engine to the front or back.
                #782342
                sx3-swe
                  They don’t need to be scientific, but if theyr’e in the ballpark I’m happy. 🙂
                  Everything goes back to my project, with the “Doria Clutch” and Minarelli front variator both beeing adapted for 17mm belts, I will need to find a proper belt.
                  However, it seem to be a mission impossible to find a belt with correct length, width, height and angle to fit this setup bolt on and perfect. I have been in contact with Continental and all other other major manufacturer regarding correct belt and only BANDO are able to get me a belt, however it would be a special made to order belt that costs 50€ + taxes for each belt and minimum quantity was 10 pcs and it’s 20 weeks delivery time for the belts.
                  Fo the SI version Ciao, there is a belt from Malossi, originally made for the Honda Wallaroo that have a correct spec, so my plan is to make my Ciao tail longer, so that I can fit the Wallaroo belt. And with the HP the Minarelli engine will provide, I’ll guess it’s not a bad idea making the bike a bit longer so that I can place my fat ass more in the middle, rather on top of rear wheel.
                  #782372
                  AA-T
                    There should be plenty of automotive companies able to help you 🤔 Belts are (or used to be) made with a large width (let’s say 1 meter) and cut to size afterwards. For instance this company still does:
                    https://duursma.nl/producten/aandrijftechniek/omspannen-aandrijvingen
                    I also know there are belts in existence you can weld together yourself. Provided you have the tools to do so, which is most unlikely. However, if these belts exist there should also be companies who use them. But finding one that’s willing to help you would probably be a headache. Nonetheless I thought it was worth mentioning it.
                    https://eriks.nl/nl/producten/mechanische-aandrijftechniek/compleet-leveringsprogramma/lasbare-rond-en-v-riemen/
                    I don’t know if the URLs provided are of any use to you as they’re in Dutch, but Google translate goes a long way 😉
                    That being said, your solution should make for a very interesting build that I would love to see. Good luck!
                    #782373
                      Those belts are meant for transport, for example a conveyor belt, and for transferring small capacities.
                      Not for high power engines.
                      #782375
                      sx3-swe
                        Thanks guys, Found some italians using a BX39 belts earlier, however it’s out of spec regarding angle and height.. Also it’s not a belt made for Variator in the beginning, I think it was belt for coolant fans in cars. The variated speed belts are often referred as “VS” in the product names.
                        I think my best option is to mill the carters, install it on the frame, then put on the Wallaroo belt over the Doria clutch and measure from the hub bolt holes to the frame holes.
                        #782381
                        AA-T
                          zevenenergie wrote:
                          Those belts are meant for transport, for example a conveyor belt, and for transferring small capacities. Not for high power engines.
                          I wasn’t aware of this but it makes sense, I stand corrected :thumb
