sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 3 maanden geleden
@Crullie, ofcourse. 😉
Left part is the adapter bracket for the caliper, see 3D rendering here:
https://vespa-ciao.nl/forums/topic/sx3s-ciao-perso-english/page/9/#post-783005 -
Thanks Guys,
Inside of the other half should be finnished upcoming days.. But it’s just a mirror so it’s basically the same.
3D printed mockup parts are finnished, will test them this weekend.
sx3-swe reageerde in het onderwerp De knutsels van zevenenergie in het forum Projecten 7 jaar, 3 maanden geleden
That look really nice! Congrats to the successful casting. 🙂
Made a visit to carter yesterday.. Here we can see that the engineer (me) have been drunk again, the VL18 reedvalve is one hell of a big reed membraan, it will need a raiser to not hit the crankshaft..
Will order a V-force3 membraan and also a raiser.. I think the V-force don’t open as much, because of more opening area.
Haha, yes me too! Don’t know how many times I’ve watched thoose vdeos.
However, there won’t be any videos any day soon unfortunatly. Next step is to machine the inside of the next carter half, so basically it’s the same toolpath but mirrored. Same same but different, not so exciting.As I mentioned in October, my mill-man trade machine hours for…[Lees meer]
Yes, thats probably how we’ll do it. Will need to make a plate with same hole pattern sÃ¥ we can bolt it onto it.
Here are 2 more movies for those who like to watch this carter come to life.. 🙂 -
1 side of the first half is more or less finnished, chamfered the bearing entry and dowel pin entry.
No we just need to figure out how to flip the piece and re-align it within decent tolerance. 😀
I agree, nice to see it come alive.. although there’s alot left still. Put some fine cuts on it today, and started out the cylinder boring, holes for the dowel pins and chamfer at the bearing seat as seen on movie.
Thanks!
Yes, I’m familiar with his channel,he do some really nice and interesting stuff, way out of my league!. 🙂
He lives in Norway, but 1km from the Swedish border so you guessed good. -
I’ve been following your progress, this carter will be really cool! 😎
Don’t know.. this Ciao won’t be finished if I know myself right 😀
Could buy a 1 way flight ticket, buy a Ciao in NL attend VCM, then ride it home to Sweden, haha.Last toolpath fortoday is finished.
Don’t know if the Dynamic milling, taking 20mm depth at 1mm engage or the crankcase is most porn. 😀
Hmm this looks familiar.. Seems like The mill-man actually started to work after some threats. 🙂Â
sx3-swe reageerde in het onderwerp Nieuwe poll: Triboron olie in het forum Nieuws 7 jaar, 3 maanden geleden
We used Triboron on 2-stroke 23cc Zenoah engines on RC cars that revved 22.000 RPM.
The piston bearing kept failing mid race season. The iPone or Motul kart oil made the engines last atleast the full season.This was 2012-2013, perhaps the formula have been improved. But I’ll probably not use it anymore 🙂
Thanks, but honestly it ain’t that hard! Fusion 360 from Autodesk is a free software and quite easy to use. I started out with Inventor (same as Fusion, but not free) same time as when I started the carter, no previous experience. Fusion can also generate G-code, if you have access to a CNC machine.
The hard part is to get someone to mill the…[Lees meer]
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 4 maanden geleden
I’m awaiting my CNC operator to start mill the case, he has done abot 50% of the toolpaths needed so still alot of work left. Meanwhile, I have cadded up the EBR fork, RPM caliper and the beginning of the hub.. Still awaiting the 260mm disc to arrive until I can make the final adjustments to the hub depth and design to match the disc. The disc…[Lees meer]
sx3-swe reageerde in het onderwerp Axle-to-axle difference between Ciao and SI in het forum General questions 7 jaar, 4 maanden geleden
Thanks guys, Found some italians using a BX39 belts earlier, however it’s out of spec regarding angle and height.. Also it’s not a belt made for Variator in the beginning, I think it was belt for coolant fans in cars. The variated speed belts are often referred as “VS” in the product names.
I think my best option is to mill the carters, install…[Lees meer]
They don’t need to be scientific, but if theyr’e in the ballpark I’m happy. 🙂
Everything goes back to my project, with the “Doria Clutch” and Minarelli front variator both beeing adapted for 17mm belts, I will need to find a proper belt.However, it seem to be a mission impossible to find a belt with correct length, width, height and angle to…[Lees meer]
sx3-swe reageerde in het onderwerp Tiesman perso in het forum Projecten 7 jaar, 4 maanden geleden
Sweet, I’ll guess you’ll put it in a ciao ciao because of the top-side inlet?
What about the Sacre carter? Not happy with it? -
Anyone have the Axle-to-axle for Ciao? tried to measure my frame and the Cadded engine and if I’m not mistaken, axle-to-axle on Ciao should be 375mm.
That would result in that SI is 95mm longer than Ciao P, if Seru.ch measurments on SI are correct.
