Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 10 jaar, 10 maanden geleden
Thanks Bas 😉
today I got the red 19″ Holland frame back from the paint shop. :rules
Piet30 reageerde in het onderwerp Piet's Simonini 4p in het forum Projecten 10 jaar, 10 maanden geleden
Thanks lightlord and Jos :thumb
First I will put the yellow Malossi drukveer in, then will make a drive video :baby
Thanks for the comments. :bier
Yes, ignition seems to be ok now.
It runs now on idle, but when I turn the throttle it stops direct.
I have installed a 92 main jet and 48 secondary jet. The mixture screw is about 2 turns out.
Do you have any Idea why this engine stops when the throttle valve opens?…[Lees meer]
Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 10 jaar, 11 maanden geleden
cool, will the frame become the match number 8 ? :baby
Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 10 jaar, 11 maanden geleden
it has a 50cc Athena
So no tuning 😀
Thanks Bas and Edjuh. :thumb
rear wheel and lock assembled.
and checked if the engine fits 😀
Piet30 reageerde in het onderwerp Lightlord's Dizzy/Gypsi in het forum Projecten 10 jaar, 11 maanden geleden
nice style, like the wooden applications. :thumb
Piet30 reageerde in het onderwerp Piet's Simonini 4p in het forum Projecten 10 jaar, 11 maanden geleden
Yes, checked two sparks also put the ignition cable direct to the spark.
Thanks. :thumb
lightlord, me too 😀
Exhaust, carb, gas cable, choke…… assembled for the first try.
But it didn’t make any noise :((
I think there is no spark, so something with the ignition.
Is there something what I can adjust on the Simo ignition?
The flywheel is fixed in position with the spie on the krukas. But is there a…[Lees meer] -
Piet30 reageerde in het onderwerp Wilk1985 perso in het forum Collecties 10 jaar, 11 maanden geleden
wuha, I never learn out here. 😀
Nice project, maybe you can put your Chinese engine in.
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 10 jaar, 11 maanden geleden
hey Jelle, what is the flower farmer saying when you roll his flowers flat with your mopeds? :haha
But the pictures are nice.:thumb
thanks. :thumb
Fred, I was thinking to put a Sprocatti in this frame as a rost oldtimer sleeper 😀
from today the 19″ frame is at the color shop to make it blue.
The front wheel of the 17″ is assembled
and the Italian Lusso headlamp for the Belgium Lusso received. :@
Piet30 reageerde in het onderwerp Fredzzz 2.0 in het forum Projecten 10 jaar, 11 maanden geleden
mmmh, delicious. 😀
Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 10 jaar, 12 maanden geleden
Thanks :thumb
Eastern is as good as gone and I had time to repair my fork legs with new brass bushes and NOS springs.
and then, into the fork with it :@
next will be the lock
Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 10 jaar, 12 maanden geleden
de poets Teufel at work :thumb
Man it is like a wonder how you get the old things looking like new. Do you have a special rost filter on your camera :worshippy
My Belgisch Lusso from 1970 also has the driehoeks lager and no bearing schaal.
Piet30 reageerde in het onderwerp Dino's perso in het forum Collecties 10 jaar, 12 maanden geleden
man, the Boxer looks good after poetsen. :thumb
Does it have 18″ wheels?
Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 10 jaar, 12 maanden geleden
Thanks Dino. :thumb
Bas, yes, it is from Belgium. 😀
I thought a Lusso has that evel headlamp what your Lusso has. And also the wave formed handelbar.
But this Ciao don’t have all that.
hi, does somebody know what that sticker stand for?
Piet30 reageerde in het onderwerp Wilk1985 perso in het forum Collecties 10 jaar, 12 maanden geleden
wow, that is an detailed report. Very interesting :thumb
Bas, after slowing down a bit, I woke up today 😀
First, made the standard black :@
and some other small assemblies
:: Piet30
