Piet30 reageerde in het onderwerp Piet30 first Moped in het forum Projecten 16 jaar, 4 maanden geleden
Hey, Nick, my next project will be ” The Italian Job” 😀
That is an Italian Frame (from Edjuh) powered with your LC kit;)
hehehe, but it is not easy to find an good exhaust what fits on that big asshole flang of DEPS 😀
Do you have some recommendations?;)
SpeedDemon, yes you are right the cylindercover is a must. But didn’t install it only for the short first run.
I’ve made a larger one than the original one from metal (see pic.) Fine tuning like that and a better air and fuel filter will follow very soon.:D
yes, there is some power. Runs very hard and agressive when I drove it some meters.:D
thanks for your feedback 😉
Yes, today I opened the gas and it made some very nice noises =)
[url=http://www.youtube.com/watch?v=mtF-YTtXIxk]Filmpje first noise MHR DEPS 47mm[/URL]
And some pics
today I enlarged the slots by about 5mm and schwups, everything fits well=):@
everything is sitting nice deep in the frame so that the engine top cover will also fit perfect.
yes, the slots are a little longer. That frame has seen a lot of different setups;)
Just in case it will not be enough. Another option will be to fit a different airfilter what is much smaller than the one what is fixed at the moment.
Man, it is a 47mm DEPS :whistle
yes, that is my fear too:con
If I need to enlarge the slots in the frame I can repaint the slots again 😀 -
Piet30 reageerde in het onderwerp Eddol – Vespa Ciao Mix (Snor) in het forum Projecten 16 jaar, 4 maanden geleden
very clean and nice job.:thumb
haha, Mike, I also was fighting with myself to chose the color. Not easy to decide on a small piece of colored paper if the color fits to the frame.
Yesterday I assembled the engine:D
Hope that there will be enough space in the frame:con
I attached the extra brackets to the baggage drager:D when I was 16.
It’s long time ago, maybe it was for reinforcement as I had fixed a small racing seat to the baggage drager at that time.As it is my first Moped from that early time I like to keep that style. I Also will keep my old red painted spark plug connector from that time. It is…[Lees meer]
😀 Arvid, 99,5 Km/h should be feasible with that springs.
Everything is wayting now for the engine.
The 2 1/4 X 17 tire fits well;)
Today I got a nice flange for my special carburetor plate
And a nice sticker about fuel mixing rate.
Piet30 reageerde in het onderwerp Piet30 first Moped in het forum Projecten 16 jaar, 5 maanden geleden
Edjuh, yes I’m selling bushes. Let me know the inner diameter you need. Some forks have 12mm and some have 13mm inner diameter;)
Mike, I’m not sure yet if the MHR with DEPS is a durable engine for the ZZT10 in that frame. Need to check.
Second choice would be the Senna Bravo with 50ccm Kick Speed 😀Martijnvanheerde, the paint was mixed by…[Lees meer]
sorry for double post, but here are some new pics from the assembled back.
Spring arms with brass bushings and red Malossi springs:D
hehehe, my wife think that I’m crazy :haha
But my son likes it.The Piaggio logo is a metal sticker. I disassembled it before painting and glued it back again after
actually 6 running Ciaos and one Bravo to finish:D
Piet30 reageerde in het onderwerp Waterpump for Polini LC kit? in het forum General questions 16 jaar, 6 maanden geleden
hehehe, high tech. 😀
But I need a 6V pump, maybe the caravan pump is for 6V
ha, that’s a great idea=)
I also have the fear that only convection will not be enough. Sure, the Polini waterpump looks cool but the caravan pump will do the job as well I think.
Piet30 reageerde in het onderwerp stöpsel kommt 🙂 in het forum Kneipechats 16 jaar, 6 maanden geleden
hey Stöpsel, jetzt mußt Du auch Holländisch lernen:@
Piet30 reageerde in het onderwerp 11 Steden Toer 2009 10&11 Oktober in het forum Vespa-Ciao.nl 16 jaar, 6 maanden geleden
you say it man, I like more the sun 😀
:: Piet30
