Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 10 maanden geleden
Thanks guys, hope this will run like it looks. =)
Crullie, yes, I used the ball bearings from the Sprocatti set. I have researched the net to find some bearings with more balls in it but couldn’t find it. All have the same number of balls in. Looks like standard for that size bearings. 😕
Piet30 reageerde in het onderwerp Docs911 in het forum Projecten 12 jaar, 10 maanden geleden
aah, I was always speculating what function the red foam in the Pinasco side inlet set has when I saw it.
Can you help me? What is the function of that foam?
Martino, I think I will put it in Bartjee’s blue frame as it has the stiffnes tubes to the labil rear end. And also already has the fixings for the radiator.
docs911, haha, maybe don’t need a carb, direct fuel flow from the jerrycan. :lol
Martino, 😀 yes, I should have milled it from a Alu block by myself, maybe next time.
I didn’t count the hours till now, let’s say it is a hobby. Otherwise I would sit in front of the TV or in a corner turning thumbs.
Engine ready now :@
Now waiting for the frame 😉
Marco, yes in advance 😀
I think I will need all stiffness what I can get. This cnc bearing holder looks stronger than the original one.
Now after the carter is fixed in right position that the kruk can turn easily without scratching the carter inner diameter the sealing surface for the cylinder gasket was not plain anymore.
So schwups…[Lees meer]
Piet30 reageerde in het onderwerp Javad's Gila. in het forum Projecten 12 jaar, 10 maanden geleden
am I seeing that right? You are coating in your kitchen oven? That is cool 😀
No it’s not my kitchen oven. I’ll have a second smaller oven for my pizza’s:D This oven on the picture is stricktly for powdercoating purposes.
Javad, yes if you buy a Sprocatti you need a big portion of creativity. And with the great support from this forum here it make also fun. 😀
FonS, tädä, and here are the 4mm spanbus (Spannstifte :lol). Thanks for helping me on that horse, it is real long time ago when I fixed parts with spanbushes. But now my grey brain cells are working a…[Lees meer]
looks like a lot of work to do. 😀
Piet30 reageerde in het onderwerp Lastpak's Citta Project in het forum Projecten 12 jaar, 10 maanden geleden
Lastpak :ik heb even afgewacht en hem toen gekocht:).
:thumb
yes, it is solid :thumb
Today I assembled the two carter halfs. That was not easy as the carters have no center ring like ori, Malo or Polini carters what brings both carter half into right middle position to each other.
So I had to disassemble the carter halfs three times till I had free turning without blocking of the krukas. :'(
But…[Lees meer]
citta1234, I think that I can finish the engine on comming weekend.
But like misterd11 said, for test drive there need to be some more work done on the frame. This is for sure not a plug and play project. 😀But Turbociao’s idea for using studs was perfect. Ignition can be fixed now easily with nuts :bier
The M6 stud what came through…[Lees meer]
tädä, studs fixed with Loctide 😉
Piet30 reageerde in het onderwerp Rickieboy zijn Xsh Simonini Retro ciao in het forum Projecten 12 jaar, 10 maanden geleden
wow, that will be a burner 😀
Are you going to drive a stronger transmission?
I’m anxious to see it running.
Rick, what cilinder bore and carb size are you using ? :duivel
I see the position of the fixing screws for the Ignition are better positioned than in a Sprocatti carter :lol
Hey Turbociao, that is a great idea, will do so :thumb
Rick, yes, that is a lot what need to be modiefied. What metal sheet thickness did you use for the modifications? 2mm ?
Is the frame still strong enough after the modifications?
EDIT says, Crullie, I do what I can :bier
next steps.
marked the modifications needed in the frame to fit the cylinder
also for the ignition
cutted a carter gasket
some corners at the piston what need to be grinded away
than the bad thing when I drilled the holes for the threads to fix the ignition.
Two M5 holes had enough wall…[Lees meer]
Piet30 reageerde in het onderwerp Florian's Projecten in het forum Projecten 12 jaar, 10 maanden geleden
Speedbuxy, if not you crazy guys, who else ? 😀
Florian! :
Piet30 :
Nice, I hope the controletties in the Harz will be at home at that time :bierI hope so too. But do you think there is a lot of police in the Harz?
Everybody drives with a Giannelli original power or Leovince SP. These are the most silent ”speed” exhaust available. Silent power:DWhy aren’t you driving with…
maybe my bones first at the next fence or wall :haha
Arvid, that is right 😉
One option was to use a scooter crank with two ends. One for the vario and the other side for ignition or water pump drive.
So this block has much potential.:D - Meer laden
:: Piet30
