Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 11 jaar, 2 maanden geleden
Man that is krass :thumb
Du putz duivel 😀 :thumb
Piet30 reageerde in het onderwerp Sprocatti sprinter, schijfremmen, costom overbrenging in het forum Projecten 11 jaar, 2 maanden geleden
for me it looks nice :thumb
What color are you planning for the frame?
nice work and good running Ciao. :thumb
Hope to see it on the Oldtimer Tour. 😉
Piet30 reageerde in het onderwerp Wilk1985 perso in het forum Collecties 11 jaar, 3 maanden geleden
Master of details :thumb
Nice work and nice weather view from your balcony.
Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 11 jaar, 3 maanden geleden
Thanks for the comments :thumb
Jelle, Viss is ordered.
Lightlord, that is an good advice. I found it at JMPB and will order it with my next order there.
http://www.jmpbonderdelen.nl/commandant-4-cleaner.html
In the meanwhile some nice brass bushings pressed into the fork arms. This should be better than the plastic stuff from the CIF…[Lees meer]
😀 I checked my wifes vanity case but she only has the version without Aceton. That is too soft :lol
Just tested the Graffiti remover at one side of the lamp housing. Not too bad I would say.
thanks Dino, maybe it is close to the original color from 1969 Verde Paraggi.
Wilk1985, that was my impression too when I Googled the RAL 6034. 😕
I thought it must be very close to the prospect color and brought my frame and stuff to the coater today.
Then I checked his RAL color cards to be sure, but on the coaters RAL color cards the…[Lees meer] -
thanks man :thumb
tomorrow I will bring the blue 19 inch frame to the powder coater.
I like to coat it in the color from this prospectI found a RAL ton 6034, do you think that will be close to the color in the prospect?
thanks 😀
Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 11 jaar, 3 maanden geleden
very nice detailed work. :thumb
Piet30 reageerde in het onderwerp Piet's Simonini 4p in het forum Projecten 11 jaar, 3 maanden geleden
update
new clutch bell from Lennaert :thumb
does somebody know if there is a special tool for pull off the Simo ignition flywheel?
Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 11 jaar, 3 maanden geleden
no, the front rim does not have the Schothorst marking and no grooves for Handbrake.
The marking on the front rim is: A 1,20×17I do not know if it is a Dutch Ciao, I can not find any NL marking on it. Is there a way to find out if it is a Dutch Ciao?
because of better quality ? :haha
Bas23, danke. Ja, ich habe es in der Liste gefunden, ist Bj. 1968 :thumb
Just started to restore a Ciao from 1970 (after my list). It looks complete (but no engine) and original.
The bad thing is that it is not original color. That is why I had to grind the area with the frame number: C7E1T *1016842* to make it visible.
after…[Lees meer]
Hi, I have a frame with frame number C9E1T*56885*
In my frame number list the C9E1T numbers start at *1250001* up from build year 1972.
Does somebody has info about build year of my frame number?
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 11 jaar, 3 maanden geleden
sehr schön :thumb
Piet30 reageerde in het onderwerp Sunny Sunday in November in het forum Pub talk 11 jaar, 4 maanden geleden
😀 I love that sound from a long mono gear ratio what only the old models can make.
When I took it out of the barn everything was coated with dark dust like mold.
but a bucket water could help 😉
I hope that we will get more of these worm days in the next weeks or month. Then I will take my time to drive some nice…[Lees meer]
Piet30 reageerde in het onderwerp Rotary disc attachement in het forum General questions 11 jaar, 4 maanden geleden
aah, thanks Crullie, very good advice :thumb
wow, thanks for the infos. :thumb
But how is it possible to get the right inlet timing?
I think it is difficult to set the assembled disc-holder with bearing on the krukas without having a degree reference. 😐 - Meer laden
:: Piet30
