Piet30 reageerde in het onderwerp HaroldPot Ciao update in het forum Projecten 11 jaar geleden
that looks nice. :thumb
Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 11 jaar geleden
Thanks. :bier
ktmgek, because it it is not easy to remove the standard. It is riveted to the frame and I don’t like to drill the fixing off to remove the standard.
I will paint it black again some time later from now. 😉
in the meantime I got the red 19″ frame back from sand blasting. :@
Thanks Jelle and Bas :thumb
update on the 17″ Holland frame.
Sand blasting and powder coating made by two different expert companies, not all from one like last times.
This has safed me time and money 😀
Salmone 830
Piet30 reageerde in het onderwerp Dino's perso in het forum Collecties 11 jaar geleden
yes, the rims are looking nice :thumb
From what build year is it?
Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 11 jaar geleden
haha, somehow like a Jedi ……ääääh Luuke, I am your father….
But nice from the top view, a kind of elegance. :thumb
nice project, I like the yellow. :rules
Piet30 reageerde in het onderwerp SJ4000 cam from webshop in het forum Pub talk 11 jaar geleden
so, my Junior fixed the cam to the stur of his Citta (unfortunately 90° turned) for a drive.
Nice picture quality :thumb
Is there a function or trick that can reduce the wind noise?
[youtube=vADrEKe_44A]
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 11 jaar, 1 maand geleden
cool :thumb
Piet30 reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 11 jaar, 1 maand geleden
yes, funny. I found that fender between other 17″ fenders in my shelf. Was wrong sorted 😀
Now I have two frames for coating the above red 17″ and the below red 19″. I’m thinking about Rosso Corallo, Salmon or Pastellblau.
this 19″ frame from 1968 has a fuel crane that I never have seen. Hope, that this is an original from the early models.
Piet30 reageerde in het onderwerp Bas23 Zijn (Oldtimer) Ciao'tjes in het forum Projecten 11 jaar, 1 maand geleden
I never have seen that lamp before.
If you have time, could you make some pictures of it?
finaly disassembled the 17″. Ready for the coater. 😀
aaand, I found a rear fender for my next 19″ project in one of my shelfs.
cool thing man :thumb
Can’t you maintain the original painting? Only nice rims with bolle rand und putzen 😀
What headlamp is that? Looks interesting.
Hey Tonni, you have pm. :thumb
Aaaah, Jelle, Marco, I’m sitting every evening in my cellar in front of the ciao hearing music while waiting for some parts from JMPB to go ahead on the Ciao. I’m fighting hard with myself then sitting there and viewing the Motobecane lamp and I like it more and more the longer I sit there. 😀
I think that I…[Lees meer]
Piet30 reageerde in het onderwerp Crank timings, original and modified? in het forum Opvoeren 11 jaar, 1 maand geleden
Inlet timing is not an universal number. It is different from cylinder to cylinder and final size of your inlet window.
There is a inlet timing calculator with what you can calculate the right inlet timing for your relevant cylinder.
Piet30 reageerde in het onderwerp Imitatie carter in het forum Carters 11 jaar, 1 maand geleden
not too bad 😀
What cylinder did you assemble on that engine?
oke, then I will stay with the Ciao lamp. :thumb
Jos, I think you will see it on the oldtimer tour. 😉
Thanks man, it make fun to drive it. 😀
For the 19″ Ciao I have now two options for the headlamp and headlamp position.
What do you think looks better? The original Ciao lamp or hte lower Motobecane lamp?
Piet30 reageerde in het onderwerp What clutch is that? in het forum General questions 11 jaar, 1 maand geleden
Thanks SuperSi :thumb
Crullie, is there something what you don’t have on your moped? 😀
It looks nice in combination with the Simo clutch bell. Did you drive this combination?
nice work, the Italian headlamp fits perfect.
Come on, centen waard is, take it and start a new project. The way is the target. :lol
thanks :bier
Dino, here we are :@
[youtube=YgupZednP_Y]
[youtube=aqklwUcNbyQ]
[youtube=N72062dtTM4]
[youtube=lKeHryLqz0E]
[youtube=-LTetY-5aXU]
:: Piet30
