Dea_944t reageerde in het onderwerp Start shoe problems 🙁 in het forum General questions 11 jaar, 4 maanden geleden
Just checked and the shoes are (unfortunately…) mounted correctly.
/Dea
Dea_944t reageerde in het onderwerp How to: complete motor tunen voor 43DR evo in het forum Oude topics 11 jaar, 4 maanden geleden
I’ve already practised when I did my 50cc Athena/Eurocilindri, was just hoping for some pictures.
/Dea
All the pictures are gone and I’m just about to modify my carter for a 43mmm DR Evo….. does anyone have the pictures available?
/Dea
Dea_944t reageerde in het onderwerp Best allround exhaust system? in het forum General questions 11 jaar, 5 maanden geleden
Thanks for all the advice!
I’ll get a Sito City power to compare
Dea_944t reageerde in het onderwerp Which cylinder manufacturer? in het forum General questions 11 jaar, 5 maanden geleden
After 1500 kms with an Athena/Eurocilindri 50cc I’m going back to the Olympia 65cc cylinder.
Performance was similar but the Olympia 65cc has much better low-end power. -
Dea_944t reageerde in het onderwerp Jettning an Athena 50cc cylinder? in het forum General questions 11 jaar, 5 maanden geleden
Problem found (and hopefully solved….)
The carburator started leaking fuel so I replaced it with a 12/10 carb with a 62 jet instead and suddenly my idle was back and the engine ran better.
I lost a little torque and power but max speed was just ~3 km/h lower so obviously there was something wrong with the 13/13 carb.Closer inspection of…[Lees meer]
Dea_944t reageerde in het onderwerp Jettning an Athena 50cc cylinder? in het forum General questions 11 jaar, 6 maanden geleden
Hi,
I followed Malossis recommendation and only increased the height of the intake window so sealing shouldn’t be a problem.
The low top speed is due to that I kept the original rear pulley, I testeed with a slightly smaller rear pulley and it reached 65 km/h without any problems, but since I don’t have a variator I want to keep the original…[Lees meer]
Dea_944t reageerde in het onderwerp Broken crank? in het forum General questions 11 jaar, 6 maanden geleden
Nice catch, I didn’t put this engine together myself so I just assumed it was the original crank….
Good to hear that the original crank is reallly strong, on my other engine I modified the original crank instead so hopefully it will hold-up better./Dea
Dea_944t reageerde in het onderwerp Which cylinder manufacturer? in het forum General questions 11 jaar, 6 maanden geleden
Thanks!
Is it considered to be a good cylinder?
/Dea
:: Dea_944t
