Ciao_Man reageerde in het onderwerp G-no's Black 'n Chrome SI in het forum Projecten 19 jaar geleden
Very nice my friend 😉
Ciao_Man reageerde in het onderwerp Search someone who can realis a pipe for me in het forum General questions 19 jaar geleden
barry :
This is my 16mm from JMPB! I have the same In 19mm also & the connection is the same!Ok very good, no problem my friend! Very nice;)
barry :
The piece is make.I take my dell-ortho carb for the measures.Here a pic of the mounting.
very nice my friend, this is a good job but on the photo, this is a 21 mm carburator no?? because me, i want to put a 16 mm caburator?? reply me! thanks man:)
Ciao_Man reageerde in het onderwerp 16 mm sneller..? in het forum Opvoeren voor gevorderden 19 jaar geleden
barry :
I will try to make this for you.Ok, take my MSN: viky67550@hotmail.com
Hello all! Does someone can realis a 16 mm pipe to speed engine for me?
I paid this person :d
Thanks you!
It’s for a dell’orto carburator, you know?
http://www.mijnalbum.nl/Foto=AMDJPPZZ.jpg
You must make 20 degrees angle…
This is instructions to realis this pipe:
first of all, you got to find a metal plate, and make a square just like the original one.
you drill 3 holes in it, 2 for the screws, and 1 for the pipe.
you find a pipe…[Lees meer]
Ciao_Man reageerde in het onderwerp Questions about new setup in het forum General questions 19 jaar geleden
TimoO_ :
first of all, you got to find a metal plate, and make a square just like the original one.you drill 3 holes in it, 2 for the screws, and 1 for the pipe.
you find a pipe with a diameter of 16 on the inside, and on the outside the inside diameter of your carburateur. and weld the pipe on the plate. with an angle of ca. 20…
TimoO_ :
here you see the 16mm branch pipe and the original.
(by G-no)here you see the piece that you got to cut off to make the carburateur fit.
but the branch pipe got to be fabricated in an angle, otherwise it won’t fit.
Can you explain with more details this setence?
For realis the pipe, I start with an original speed…[Lees meer]
coda :
The pipe is easy to fabricate,but if you want to shove your carb over the pipe the left side of it contacts the left part of your engine,so you hae to remove some material of your engine to make it fit.
You can use a dremel tool for this.Ok! Very good explications! Thanks you Coda!
I search some plans or pictures in order to…[Lees meer]
TimoO_ :
this is 16mm carburateur with a special branch pipe made for a speedengine. but it doesn’t fit without cut off a piece of the speedengine. but that doens’t care that much, couse the piece that you got to cut isn’t that important.
Ho! It’s very interesting! Have you got more informations about this? Have you got plan or picture…[Lees meer]
Mike :
check my edit link what i mean 😉 because i do’nt think you have that gears setYes I have saw!
I don’t have this malossi’s parts but i have already a 9.5 turns
Mike :
i think you can get upto a 90 km’h but only if you have the malossi gears in your variatorclutch .. becase if you have not… you wil go 70km’h max..I have at back an yellow malossi arises and 9.5 turn!
Thanks you for your very fast answers!!!
I think i take the NINJA Usine!
So, you think how many max speed withPolini speed engine dremel
Polini 42 mm alu
13/13 or 15 vergasser
Malossi Variator
Giraudo Krukas
Ninja UsineThank you 😉
:: Ciao_Man
