Home › Forums › English › General questions › Questions about new setup
- Dit onderwerp bevat 18 reacties, 6 deelnemers, en is laatst bijgewerkt op 19 jaren, 1 maand geleden door TimoO_.
18 maart 2007 om 18:32 #144127
Hello all!
I Want to know what is the best auspuff between NINJA usine, MALOSSI too bad, Proma Circuit, for this setup:Polini speed engine dremel
Polini 42 mm alu
13/13
Malossi Variator
Giraudo KrukasCan i put a 15/15 Vergasser on speed engine if i tuned the carters?
Thank you!
18 maart 2007 om 18:38 #145354i think an 15/15 will be difficult to make it fit to the engine.. but you can try to tune op your 13 13 tot a 14 14.. some members here already have done that and ther’se a how to for that..
and i think you should try the ninja usine becuase he can handle allot rpm… the same thing counts for the proma cc and toobad but the ninja is best i guess.. and it’s also a very nice exshaust to be seen 🙂
Mike18 maart 2007 om 18:39 #1453554 every setup i prefer proma circuit , but the toobad(malossi circuit) is also verry sweet on vario just like ninja.
only a 15/15 is too much for the carter , is don’t fit.18 maart 2007 om 18:40 #145356You can put a 15/15 on your speedengine if you make an home made intake (spruitsuk?manifold) And about the exhaust, al 3 are nice it’s just what you like the most.
18 maart 2007 om 18:46 #145357Thanks you for your very fast answers!!!
I think i take the NINJA Usine!
So, you think how many max speed withPolini speed engine dremel
Polini 42 mm alu
13/13 or 15 vergasser
Malossi Variator
Giraudo Krukas
Ninja UsineThank you 😉
18 maart 2007 om 18:51 #145358i think you can get upto a 90 km’h but only if you have the malossi gears in your variatorclutch .. becase if you have not… you wil go 70km’h max..
http://www.jmpb.nl/shop/view_product.php?product=VE3254
this is what i mean 🙂
Mike18 maart 2007 om 18:53 #145360Mike :
i think you can get upto a 90 km’h but only if you have the malossi gears in your variatorclutch .. becase if you have not… you wil go 70km’h max..I have at back an yellow malossi arises and 9.5 turn!
18 maart 2007 om 18:55 #145361check my edit link what i mean 😉 because i do’nt think you have that gears set
** ah sorry i already see what yoy said.. so you have the malossi gears set!! thats very nice and you will drive FAST!:bier **
Mike18 maart 2007 om 18:58 #145362Mike :
check my edit link what i mean 😉 because i do’nt think you have that gears setYes I have saw!
I don’t have this malossi’s parts but i have already a 9.5 turns
18 maart 2007 om 18:59 #145363okee:D very nice:) you wil go very fast i think.. succes whith your ciao!
Mike18 maart 2007 om 19:18 #145365
this is 16mm carburateur with a special branch pipe made for a speedengine. but it doesn’t fit without cut off a piece of the speedengine. but that doens’t care that much, couse the piece that you got to cut isn’t that important.
18 maart 2007 om 19:37 #145366TimoO_ :
Ho! It’s very interesting! Have you got more informations about this? Have you got plan or picture for realis this? Can you explain what piece cut off of the speed engine?
Thanks 😉
18 maart 2007 om 20:30 #145367The pipe is easy to fabricate,but if you want to shove your carb over the pipe the left side of it contacts the left part of your engine,so you hae to remove some material of your engine to make it fit.
You can use a dremel tool for this.18 maart 2007 om 20:44 #145368coda :
You can use a dremel tool for this.Ok! Very good explications! Thanks you Coda!
I search some plans or pictures in order to realise the pipe. if someone have that, reply! Thanks
18 maart 2007 om 20:48 #145369
here you see the 16mm branch pipe and the original.
(by G-no)here you see the piece that you got to cut off to make the carburateur fit.
but the branch pipe got to be fabricated in an angle, otherwise it won’t fit.
