Witch one would you take?
Home Forums English Pub talk Witch one would you take?
  • #147452
    Blacklisted
      Hello guy’s, like the topic witch one would you take? Witch one would perfom best?
      Polini Evolution Engine
      Polini 73cc kitt
      Polini vario
      Dellorto 19mm
      Malossi MHR crankshaft
      Special Belt
      Or
      Simonini sideinleet
      19mm Dellorto
      Special Belt
      Eurocilindro 73cc
      Polini vario
      Probably Malossi crankshaft
      My english is not the best, so i hope you guys understand 🙂
      From Sweden
      #147962
      QuicklyHeizer
        I think the second setup will run better 😛 I don’t know the eurocilindro 73cc. Is it the same like the 73 ccm Athena? Then I wouldn’t take this cilinder, i would put a 73cc Pinasco Black edition on the engine.
        #147963
        olliegasselt
          @ Blacklisted ,
          i would take the second option !
          #147961
            Euro 46 ftw! Especially if it’s the 28mm exhaust version.
            #147964
              Definitely the second option.
              The side inlet is a lot bigger and more direct then the inlet of the Polini Evolution engine.
              As for the cylinder, there are many versions of the 46mm Eurocilindro, but the one Edjuh described is the fastest.
              Almost the fastest 46mm cylinder there is for our vespa’s.
              #147966
              Blacklisted
                Okey tnx guys 🙂 What do you guys think that top speed might be? On engine 2 🙂
                From Sweden
