Why max 25km/h
Home Forums English General questions Why max 25km/h
  • #778607
    jacekniemiec
      Hello You All !
      I have two ciao mix – one run like devil and second one goes max 25 km/ h plus is not keeping slow ‘parking’ rpm – engine is stopping after few second of ideling. Carburator was cleaned with ultrasonic cleaner, ( I try carb from the first ciao mix – no change ) .
      I try diffirent back weel (diffirent hubs) – also no change.
      Can that be the the CDI ? Or something else ?
      All the best !
      Jacek
      #778608
      jacekniemiec
        Now it came to me – maby it is a simmering on the crankshaft ?
        No sight of oil leaking from simmering in magneto aera under the engine ..
        Maby something else I dont see..
        carburator 12.10
        12mm intake in engine..
        Hmmmm…
        #778612
          Hi jacek,
          Maybe a bit more information to help you ahead. You have two Ciao mix mopeds and one is not running good and is slow ?
          Best would be to take some pictures and a video. Furthermore:
          1. How old is this engine? Did you revise it before ?
          2. Did it always had this speed or was it faster before?
          3. What cilinder is mounted, maybe your need to check the pinston if it already drove many km’s ?
          4. Did you try another spark plug already ?
          5. What is your complete setup ?
