All the overrange stuff from Malossi is almost identical to Minarelli scooter parts, with some minor differences or work to have done on these parts. The splines on the ingoing shaft are the same as Minarelli, so you can use any clutchbell you like 105 or 107 does’nt matter.
On the left a worked Minarelli Pulleys and Malossi Fly clutch for Minarelli, right the Malossi Pulleys. The thing you have to remember is that you have to work the rotation, Minarelli is normally anti-clockwise and our mopeds rotate the other way around. so make your own keyways in the pulleys and for the clutch you need to have these other clutch shoes. These will fit on the Malossi fly clutch from Minarelli.
