15 berichten aan het bekijken - 4,711 tot 4,725 (van in totaal 5,103)
  • #38765
      Meer olie zal alleen maar je bougie laten dichtkolen. Gewoon 1 op 45-50 mensen zoals normaal (2%) is echt voldoende. Dat zou ik doen.
      b.baens
        Beste mede forumleden, ik heb nu een nieuw blok opgebouwd maar zou niet weten met welke sproeiermaten ik zou moeten beginnen.
        – Reedvalve Elec.
        – Malossi volle wangen krukas p10
        – 17 mm dellortho carb
        – 43 mm DR Evo
        alvast bedankt,
        b.baens
        #40220
        thierry93
          Oke heb het gelukkig er nog niet bij gegooid! Bedankt voor de tip
          #68453
          si-sovrano
          Lid
            welke sproeier ben ik nodig bij de volgende setup?
            41mm zeta
            12/12 carbarateur
            Proma/tecnigas cc
            Malossi luchtfilter
            std carter
            Bij voorbaat dank
            Nick
            #68304
            Guido
              62-66
              #118681
              rubymax
                Hello!
                Can you tell me which nozzle do I need for the following setup ciao PX eco model?
                – Cylinder and carter: standard
                – Carb : dellorto 13/13 with Malossi air filter
                – Pulley : standard 95 mm
                – Exhaust : Gianelli FIRE
                At that moment I have 0,56 but the acceleration is poor.Do you think I need a smaller one. I also want to change the standard pulley with 80 mm but I am afraid that the acceleration will be then even worser.
                Thank’s for the answers
                #118682
                  @ Rubymax
                  I think the .56 jet is more or less ok, but you just took the wrong exhaust for this setup. In my experience, the Gianelli Fire is an exhaust that is not made for standard setups.
                  This exhaust simply does not have a lot of acceleration power on pulley setups because it needs high revs to perform.
                  #118683
                  rubymax
                    Wilk1985 :
                    @ Rubymax
                    Wilk 1985 you are 100% right about the acceleration power about Gianelli fire unfortunally now is too late because I just get it from Easy parts.Nl yesterday. I also replace my standard clutch segments with malossi special clutch segments with included black springs but I replace the black malossi springs with the original today, because I think they are too tight for my set up.
                    Otherwise I am satisfied with final max speed but it takes time to get it.
                    Do you maybe have some other solution what can I do ?
                    Best Regards
                    #118689
                      rubymax :
                      Wilk1985 :
                      @ Rubymax
                      Best Regards
                      There are 2 things you can do:
                      1. Get an exhaust that fits your setup (Like Citypower of Leovince Circuit)
                      2. Get a setup that fits your exhaust (+41mm cylinder)
                      If you have any more questions please start up a new topic in the English section because this section is meant just for small jet related questions.
                      #118697
                      sen-der2
                        Welke sproeier ben ik nodig?
                        Ik ga met mijn setup naar een 50cc snel van het merk dr
                        Ik heb op moment 41 daar loopt hij goed op
                        #118702
                        rubymax
                          Welke sproeier voor deze setup>>>? – 50cc standard
                          – ECO zuiger
                          – Carters std – original
                          – 13/13, malossi filter
                          – GIANELLI city power
                          – Poelie 80 mm
                          – Ciao
                          #118727
                          SnoopJ
                            13/13
                            70 CC mallossi
                            Verder alles standaard.
                            #118656
                              @sen-der2, als hij goed loopt waarom veranderen? Check je bougiekleur
                              @rubymax, 52-54
                              @SnoopJ, 60-62
                              rubymax
                                Welke sproeier voor deze setup CIAO:con>>>?
                                – cilinder : OLYMPIA kit 43 (65 ccm)
                                – carters: 12 mm inlat
                                – 13/13 , malossi filter
                                – uitlaaat: GIANELLI FIRE
                                – poelie: 80 mm
                                #118756
                                Flippo
                                  @rubymax, 60-64. Ligt eraan of je carters zijn bewerkt of niet.
