Very hard compression on my Polini Evo Ciao?
Home Forums English General questions Very hard compression on my Polini Evo Ciao?
  • #144321
    Maarike
      Hey everyone!
      As the title says, it is almost impossible to start my Ciao, the one time I actually got it started was when I sat down on the Ciao and my brother pushed me 40-50 meter a long the road.
      How can I fix this?
      I got a normal clutch, with normal springs on it, it’s a Polini Evolution engine with a 46 mm polini cylinder.
      BTW I have bought the Simonini clutch house, but it seems like nothing fits in it, why?
      Thanks!
      #145987
        Do you use choke? It can be crucial on 19mm dell’orto’s. Also, what size is your main jet?
        I had no problems transferring the piaggio clutch parts to the simonini housing.
        #145764
        pepko
          do you mean tou have too much compression?
          do you use the decompression handle while running?
          is your V-belt tensioned?
          gr. pepko
          #145772
          Maarike
            Yea sorry, I mean compression,
            i think the problem is in the clutch, the clutch has a hard time to make the grab and rotate the piston/flywheel
            But when the clutch is too tight, there compression all the time.
            #146451
            cittamark
              i had the same problem, with my ciao 25kmh engine, it could not stard the dam thing.
              changed engine to 45kmh And i replaced the spring’s on the clutch with polini green once instead of origional.
              #146452
              Maarike
                I have the polini springs in my inventory, so I will change the standard springs with the green ones. Thanks so far guys!
                Another thing, I got that horrible Tecno Reverse Exhaust, it sucks! So would it be better to change it with the Polini Top One?
                #146453
                pepko
                  regarding the exaust swap: definetly yes!
