TK: Second series CNC 101 crome half pulley variator
Home Forums Advertenties Onderdelen aangeboden TK: Second series CNC 101 crome half pulley variator
  • #246179
    gab_pei
      second production.
      c45 steel plates made from full and then chrome.
      bushing of excellent quality, obtained from full and then brought into tolerance
      60 euro + shipping
      great if coupled with the bell Alu.
      #246823
        Do you have a 108mm version of this discks?
        Avete una versione di 108 millimetri di questo discks?
        #246822
        gab_pei
          Next week will be ready.
          #249844
          gab_pei
            #249845
            Coopering
              Looks great! I already have the new plates. Can the belt go deeper into, so that I can use the full possibilitys of my multiva or speed control ?
              Which exact belt do you recommend?
              I always kill my bearings of my gear. Of the outgoing axle. The old c40 clutch of you is way to heavy, but even the original clutch is to heavy and killed the small bearing. How do you managed this problem?
              #249851
              gab_pei
                the change of measures of half pulley allow to fully open the drive malossi.
                we are testing a new cover for the hub drive.
                #249854
                  Excellent work! What’s the diameter of the pulleys?
                  #249857
                  gab_pei
                    2 version: 101 mm and 108 mm.
