simonini/mazzuchelli crank
Home Forums English General questions simonini/mazzuchelli crank
  • #803122
    AIRMECH
      shims or no shims in a malossi mp1 casing.?
      I noticed that thecrank already has 0.3 shoulders on the webs
      #803123
      Fredzzz
        If it’s one of the full circle cranks, then no shims are needed.
        Post pics to be sure though.
        #803131
        AIRMECH
          Measured casings and cranks and figured it out,took a bit of time to get the Exhaust and transfer timings I wanted as the rod length is also 4mm longer but all good now,now to tune the DEPS cylinder😀
          crankcase machining done and 19mm phbg carb reamed out to 21mm
