simonini 46 stroke crankshaft
Home Forums English General questions simonini 46 stroke crankshaft
  • #799320
    AIRMECH
      Hi Guys anybody know what machining is necessary to fit the 46 stroker into a set of malossi casings ?
      #799323
        In case of a Simonini 46 stroke crank, these have 74mm diameter cheeks, so you have to machine the Malossi casings by 2mm or more. Also because of the wider connecting rod you need to cut down some of the inside of the casings otherwise this connecting rod will scratch the casing.
        #799429
        AIRMECH
          ok Martino thankyou 🙂 ,
