:: Questions about new setup
TimoO_ :
here you see the 16mm branch pipe and the original.
(by G-no)
here you see the piece that you got to cut off to make the carburateur fit.
but the branch pipe got to be fabricated in an angle, otherwise it won’t fit.
Can you explain with more details this setence?
For realis the pipe, I start with an original speed engine 13 mm pipe?
first of all, you got to find a metal plate, and make a square just like the original one.
you drill 3 holes in it, 2 for the screws, and 1 for the pipe.
you find a pipe with a diameter of 16 on the inside, and on the outside the inside diameter of your carburateur. and weld the pipe on the plate. with an angle of ca. 20 degrees.
TimoO_ :
Ok! I have understand! Thanks!
You don’t sell this parts? Or you don’t creat this for me? I paid you 😉
no, i’m sorry. i’m busy with it myself trying to build it on a original carter. but it’s very simple. the carburateur is a carburateur of a Tomos. so you can order it on a online shop, or maybe your local shop has one.
and for the branch pipe you got to find someone who can weld the two parts together for you ( think MIG/MAG will be the best). with a drill and ironsaws i think the parts are easy to fabricate. just buy or find a piece of metal and a metal tube and customise it.
