Please take a look at my inlet
Home Forums English Pub talk Please take a look at my inlet
  • #147434
    eran_k
      Hi,
      I opend the case for port matching and enlarging the inlet.
      the stock inlet on my motor looks to be already bigeer (on the inside) then on many photos i saw here on the forums and in the how to guide, the diameter of the “round” part is 11.5mm
      here is the picture
      the question is:
      how deep i need to drill with 13mm?
      should i also enlarge the opening on the inside more? and how much?
      thanks!
      Eran
      #147894
        You need to drill 18mm deep. Not more 😉
        You don’t need to enlarge the inside of inlet. It’s big enough for you cylinder.
        #147901
        eran_k
          i didnt mention that all this work is for installing a 65cc kit on it
          #147902
            Than the inside is still ok 😉
            #147905
              If you drill it to 13mm diameter and ‘flow’ the tube into the rectangle you’ll have a nice inlet.
