Motor after rebuild question
Home Forums English Pub talk Motor after rebuild question
  • #147438
    eran_k
      I finished putting my carter back togehter, after i installed the oil seals (i have 2 – kick carter),the crank doesn’t turn freely as it did before the seals, i did make sure the seals are installed level with the edge. is this normal for new seals?
      thanks
      Eran
      #147924
        Yes, it is normal your crank cannot rotate as freely as before installing the seals.
