:: MofaFreak´s Ciao ST
Home Forums Perso’s Projecten MofaFreak´s Ciao ST
15 berichten aan het bekijken - 31 tot 45 (van in totaal 65)
  • #435285
      Nice video, the thing really flies….
      #453995
        It is incredibly fast 😀
        Don’t you think you need a helmet at 100km/hours :pest
        1-feb
          Damn so fast… and without a helmet, youve got a deathwish?
          #436202
          diac
            “aaaah… sheiße” ^^
            damn, give it wings and it will fly.. o_O
            #438150
            Daan777
              I think none of us expected the pinasco was SO fast!
              It had a reputation of a very LOW rpm cylinder.
              Shame, JMPB charges 160€ for it now.
              #433803
              MofaFreak87
                THX allot to you guys
                jeah im shamed that i dont were a helmet on that video
                but i had nothing to put the camera onto so that it isnt staying on the ground 😕
                on one way i made 96 but the waights were to light
                today i bought 5,5 gramm but this is a bit to heavy grrrrrrrrr
                lets see the next days how it runs on longer time with that waights
                when it istn good i will buy 5,2 or 5,0 gramm
                this will hopefully do the job
                @daan: i dont expextet it too that the pinasco is that fast
                but i think when i want to reach more speed i´ve got to drill the window from the outlet 0,5mm more up
                and than i got to calculate a exhaust by myself
                this is hard work but its the best hobby you can have :thumb
                regards from germany to you guys
                Marc
                #433798
                Mike
                  awesome speed.. did you tried already different exhaust systems?
                  like fabrizi …
                  Mike
                  #433953
                  MofaFreak87
                    no i didnt try it with the pinaco
                    but it will be verry interresting 😀
                    #454346
                    Frankie
                      Great Ciao !
                      I want the excact same ST colour for my ciao 😀
                      i love yours !
                      :thumb
                      #454351
                      MofaFreak87
                        Hi Frankie
                        jeah this is also my favorit colour since more than 4 jears ! i love it very much
                        update
                        at monday i was on my test track round my village and made some wheelys and videos
                        everything runs smooth and verry nice
                        but than as i wantet to drive home it didnt feels good
                        some seconds before i hat to switch on “reserve fuel”
                        i used the shoke because with it i can drive again without to stop and wait that the carburetore gets full with fuel
                        100 meters after i switched to reserve it didnt feel very good
                        i needet more and more power to get on 70 and it was like i´am using the brake when i went off the gas
                        so i stopped immediatly and bufffff…. engine was dead
                        hmmmmmm what the hell …. i tried to turm my crankshaft / multivar but it was damn hot
                        after some minutes i turn it again and i could feel that the zylinder still got kompression
                        but its turning really heavy
                        so i know my special bearings are broken
                        see this
                        my first look in the engine was hääääää … there isnt anything broken but when you look exact you see that the
                        cylindrical roller bearings Cart was damaged
                        between the 2 rolls you see that the cart is melted
                        but why happend that? i think because malossi didnt made this channel from the top in the carters like polini or std engine
                        malossi made just this little borehole and thats it
                        hmmmm i will drill it now in there like std engine and polini makes it
                        i will hope that i wont get this problem again 😀
                        greetz marc
                        #454352
                          Just buy normal bearings with a plastic cage….. there 7.50 at jmpb.
                          I think its totally useless to drive with bearings which cost 25 euro each.
                          You dont have a cilinder which rev’s 13000 RPM.
                          Check: http://www.jmpb.nl/store/index.php?act=viewProd&productId=1555
                          Also bearings can die… allot of users drive with reedvalve engines so i think you just had bad luck.
                          #454349
                            Just don’t buy plastic cage bearings at all. If you make high RPM they just get too hot appearantly.
                            And I know that Herr Flick also drives with the TN9 bearings but he almost never drives his Ciao in high revs for longer periods, which you do a lot.
                            I would advice the standard bearings, they have more than enough buffer. What I always did when I drove around a lot was change them every six months. But even that isn’t really necessary, i did that just for myself, to feel safe…
                            The RPM limit on an ordinary SKF 6202 explorer bearing is 28000 RPM, that should be enough..
                            #437959
                            MofaFreak87
                              heyho
                              @ hansieb: i dont mounted these bearings because of my power or my rpm… no question that i dont reach this rpm !
                              the reason for that zylindrical bearings is because i can put the engine in less than 10 minutes together and apart
                              i dont like it to heat the carters everytime when there is something wrong
                              and i dont pay 25 € dude ^^ its unter 20 €
                              @tonni: TN9 bearings? these are the ones from JMPB ?
                              i will say so… when these zylindrical bearings crashes again i will get some with a “messing korb”
                              like that
                              undestroyable 😀
                              #439103
                              Daan777
                                DUDE
                                Where can i buy those bearings?
                                #439045
                                  Het zijn NKE lagers. Industriele kwaliteit. Op hun site staat niet waar je ze kan kopen.
