sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 6 maanden geleden
I sent back The cylinder today, Because I found some cavitations when inspecting it. Not what to expect from a high end cylinder..
What do guys think?
Thanks! Parts, anyone can buy.. The big task is to get the carter done 😮
The reedvalve is Malossi MHR VL18, especially designed for the Malossi C-one crankcase, but is has AM6 dimensions.
Base of triangle is 36,5mm,
Height of triangle is 35mm
width of triangle is 45mmThe base-plate is not included in the dimensions.
Is comes with 28mm…[Lees meer]
All I’m waiting for is a stupid MaxiScoot order that they are struggeling to ship out, been waiting 2 weeks and I’ve tried to cancel it but they don’t listen. 🙁 As soon as I receive it, I can make the final adjustment to the 3D model, then let my friend print it for me.
Anyway, I’ve collected many parts needed, still some to.. like exhaust, but…[Lees meer]
sx3-swe reageerde in het onderwerp TK: VL8 membraan in het forum Onderdelen aangeboden 7 jaar, 6 maanden geleden
Side inlet kit is now Sold.
The “Klein carter” is self made, I cannot garantuee its function or how the cast-aluminium might have been affected by TIG welding it. Because of this, the klein carter is for FREE, for the person who buys
“Spruitstukset Malossi Incl. Membraan” + PHBG 21mm.Basically you get everything in the photos except for:
– New VL8 membraan in original…[Lees meer] -
AMT002 is sold.
Edit: AMT206 is now sold aswell!
I have added new items! 🙂
sx3-swe reageerde in het onderwerp Tiesman perso in het forum Projecten 7 jaar, 6 maanden geleden
Nice, is that you engine with the 2Fast cylinder? Will you run BBK or the 70cc version?
I can’t decide if I should go 2Fast or S6 R/T, the S6 price is a bit better but from what I heard the 2Fast delivers 2Hp more out of the box.The selettra binnenrotor, is it the MHR Team version with CDI? Will it be necessary to rotate the rotor 180 degrees…[Lees meer]
Just some minor adjustments left, then I will 3D print a mockup in the upcoming weeks.
I will not CAD the transfers, thoose will need to be matched by hand so I leave them out..Can’t decide weither to go with 2fast 70cc or S6R/T 70cc.. decisions decisions..
That goes for the uitlat aswell..
Pinasco black, 46mm..Verkocht/sold!
Simonini Calibrata 22mm.. Verkocht/sold!New items added! 🙂
Updated the ad!
I think I saw that one on Italian Ebay a couple of month ago?
Cristofolini have a similar carter:
http://www.teamcristofolini.com/imsearch.php?search=ciao -
Yes, my own case, thats why I’m selling the other project so that I can finance this bad boy 😀
Yes, they’re both Minarelli style cases for Ciao/bravo/Si 🙂
I try to adopt as much mineralli parts as possible, apart from the obvious..
– Dowel pins, bearings, oil seals, reed valve, manifold and so on.. So every parts except for crankcase should be…[Lees meer] -
Yes, it would be kind of time consuming to both produce all fans, but also test them out..
Some small progress on “the dream” 🙂
I just haven’t figured out the stator position according to the rotation of crank..
@AA-T: Sorry for late reply, didn’t notice your post!
I did it after a bit of research and looking at fans for other motors, not vespa motors.
Nice! 🙂
It would be interesting to see how the frame can be modded on a Ciao without loosing the rigididity. I have searched for some inspirational pictures, but thoose Italians are keeping them photos a secret. 🙂Much easier with citta/bravo/Si brug, but the Ciao is still a mystery.
How will a Minarelli style exhaust fit theese types of…[Lees meer]
sx3-swe heeft het onderwerp TK: VL8 membraan aangemaakt in het forum Onderdelen aangeboden 7 jaar, 6 maanden geleden
Parting out the motor instead,
Mazzucchelli AMT002.. Verkocht/sold!.
Mazzucchelli AMT206. Verkocht/sold!
PHBG 21mm + Malossi reedkit (Spruitstukset Malossi Incl. Membraan). Verkocht/sold!
Malossi VL8 membraan.. Bought it 2014 i think, still in original pl…[Lees meer]
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 7 maanden geleden
@Martino, i understand that.. Unfortunatly the engine is pretty worthless without the fan.
But talk to @Fredzzz, I have sent him the STEP file, maybe Moparts can hook you up with a fan?Send me a PM with your home adress, I can sponsor you with the 2-piece 3D printed mockup if you want it to elaborate fitments, or use it as a frisbee or something, 🙂
Thanks guys!
For the right buyer, the complete motor is for sale. Anyone interested, send a PM for further details and bid.Today I tried to fit the polini variator I bought 3½ years ago, seems like they were drunk at the factory. The hole inner disc is offset and impossible to align with the bushing. Think it will be hard to get a new one from…[Lees meer]
Well, now its time to go home…
Geting close, geting tired!
:: sx3-swe
