sx3-swe reageerde in het onderwerp Polini airfilter, extra holes in het forum General questions 6 jaar, 11 maanden geleden
Perfect, thanks!
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 6 jaar, 11 maanden geleden
Daily driver engine is almost finnished, eager to test it and see IF it perform!
Polini have really shitty castings nowadays, sad to see 🙁
Alright, so in total 5 pieces of 6mm holes, where as 3 of them are already present.
I need to drill up 2 pieces of 6mm holes. -
sx3-swe heeft het onderwerp Polini airfilter, extra holes aangemaakt in het forum General questions 6 jaar, 11 maanden geleden
Hello,
Setup:
– Polini SE + Polini Airfilter
– SHA 13/13
– DR43The instruction for SE-carter says I should drill up some holes in airfilter, how many 6mm holes do you recomend for above setup?
sx3-swe reageerde in het onderwerp Tiesman perso in het forum Projecten 6 jaar, 11 maanden geleden
@Flick, I think it’s from Tiesmans “hofleverancier”, GP-Racingparts in Italy. 🙂
That Ciao looks mean Ties, looking forward to see it completed. 😀
We are behind the schedule because of problem with the mill.. We have big noise and vibration that are escalating. We have changed tension washers on drawbar and also bearings on the spindle.. Hopefully we can start test the machine within next 2 weeks. Haven’t given up on the carter. 🙂
Meanwhile, I have bought a new Ciao, meant to be a daily…[Lees meer]
sx3-swe reageerde in het onderwerp What have I bought? (Ciao) in het forum General questions 6 jaar, 11 maanden geleden
I’m always on my own! 🙂 And this is a trojan-horse, deifinatly not made for the Swedish market as the Ciao max speed never been above 25km/h.. 😀
So I opened the engine today at it seem to be a “belgische” carter.
And as far as I know, from reading this thread, it is a brom-kruk…[Lees meer] -
Okey, so when the ring is present it’s not possible to drill the inlet? Or is it not possible to make it wider from the inside?
Are you sure the ring isn’t a reinforcement for the carburator, so the inlet doesn’t snap off so easy?Based on 22,5mm uitlaat and straight inlet, the it would be safe to say that the carter isn’t restricted and a DR43mm…[Lees meer]
Yes, that steel busing is familiar! Thoose are common in Swedish standard carters..
I have measured by oulet/uitlaat and is measure ~22,3-22,5mm
I managed to take some photos from the inlaat aswell, it looks unplugged??
Hmm never seen one of thoose restrictors before..
Is it esy to pluck out? Do I have to cut it?
Perhaps there is an dutch instruction on the forums? -
Thanks,
Funny, larger outlet = restricted/limited.
I think the steel ring/bushing already is plucked out, see picture 3.. The inlet is 11,5mm.
I’m looking at DR 43mm, according to JMPB this will not fit this carter? I thought 43mm would fit all carters, but 46mm needed to be reworked.
Is this the DR-EVO?
https://www.jmpbparts.com/vespa-ciao-si/engine-parts/cylindres/dr-cilinder-43mm-vespa-p10.html
Ohh, it looks like there is potential for improvements in the carter..
The grote carter is manudactured 1998, but yes I’m pretty confident this is the last model..
It looks like there have been a steel bushing in my carter that someone have took out, the surface look honed.
Perhaps I can look inside the inlet without splitting the engine, finding…[Lees meer] -
sx3-swe heeft het onderwerp What have I bought? (Ciao) aangemaakt in het forum General questions 6 jaar, 11 maanden geleden
Hello,
Picked up this boy today, ZAPC24 with C241M engine. It has mono gear and from what I understand it’s a 2002 year model?
The grote carter is stamped 98, and klein carter is stamped 97, engine says C241M on it, as well as VIN plate. The VIN-plate also says “10R-01.4138” under engine.. I don’t think it’s the original engine fitted? Or perhaps…[Lees meer] -
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 1 maand geleden
Couple of more pictures
It’s been a while since last and it’s mostly because we had a major set-back with tolerances.
The machine seem to miss steps or there is a bug with backlash compensation.
The seatings for the bearing were ofsetted with about 0,35mm on Y axis.
We have corrected this by re-milling the “keys” to oversize and making custom keys, instead of Minarelli…[Lees meer] -
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 2 maanden geleden
Hehe, well then it’s time for next episode 🙂 Now it’s really looking like the 3D model, it’s satisfying to see something go from sketch in computer into something you can touch!
One side is almost finnished, only som chamfers and a screwhole left!
As usual, a small video clip in the end.
Which holes are you referring to?
The frame is, as is in earlier post in the thread.. I’ll need to finnish the carter before I know where to reinforce because I will need to cut the frame a bit to fit the carter in place because of double sided crankshaft.Some more progress on the carter, starting to look like the 3D model.. Exciting, if it…[Lees meer]
Fixture for milling The other side of The carter.
Mirror mirror on the wall……….
