sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 6 jaar, 10 maanden geleden
Revised the fork. Also installed the Moparts bearing.
There wasn’t any manual with the bearing kit explaining which nuts to keep and washers to use where.
I have a conical nut + washer inside the brake shield atleast.
sx3-swe reageerde in het onderwerp Malossi Remsegmenten in het forum Overige mening & ervaring 6 jaar, 10 maanden geleden
The brakes have arrived.. 🙂
My first impression is, theese are probably the same as Polini brakes but new color and other package..
So why would I say that?
…Because, the casting on the rear brake says it was manufactured “06”/2006 as from reading this post, @Wilk1985 noticed the same thing with Polini…[Lees meer] -
A couple of Pinasco stuff have arrived, will rebuild the fork with brass bushings and front wheel bearings.
Also arrived a 11,5 vario, installes malossi black clutch-springs in it and the yellow pressure spring.About the Minarelli-Carter, there have been some progress with repairing the mill.. I estimate we can test the mill to see if vibrations…[Lees meer]
Alright, I measured original DR paper gasket to 0,3mm.. Perhaps going for a thicker 0,5 and adjust the squish by grinding the top is the way to go. Are the thinner gaskets prone to break, hence 0,5mm?
Is anyone using gasket for cylinder head?
Do you guys prefer the blue or yellow gasket from JMPB?
Yeah, I’ve thought about paste aswell! Will need to get some 🙂
Do you cut your own gasket? Which paper do you use? To many thicknesses to choose from at JMPB 😀
Wow 62, that was quite low? Sproier database says high 64-68 with 13mm inlaat, well I have SE-carter that would be similar I guess. Perhaps I should try 64 and B8HS and see how it acts.…[Lees meer] -
Didn’t know 67 even existed, thought it was only even numbers.. Have to check that out!
However, in my opinion the engine runs a bit rough, sound of meetal.ticking that one would expect with a expansion uitlaat, with the citypower, also a little bit nervous on the idle.. What do you guys think?
Also I have leakage, probably that’s why I’m…[Lees meer] -
sx3-swe reageerde in het onderwerp Nieuwe Pinasco onderdelen 2018! in het forum Nieuws 6 jaar, 10 maanden geleden
Thanks! Sound nice, more like a scooter rather then a tired vespa engine. 🙂
I have ordered one from Italy now. -
sx3-swe reageerde in het onderwerp Continental semi go 16 x 2.25 in het forum Brommers algemeen 6 jaar, 10 maanden geleden
I haven’t installed them yet, received them last week. So I can’t tell how they perform.
However, the rubber is very soft, so I expect them to have good traction in tarmac, but probably not the best tire in wet conditions because of pattern
I think they will wear out quite quickly, because of softness.
Continental is a premium brand, I don’t think…[Lees meer] -
sx3-swe reageerde in het onderwerp Nieuwe Pinasco onderdelen 2018! in het forum Nieuws 6 jaar, 11 maanden geleden
Nice to hear, I searched youtube for a sound check, but didn’t find any.. If you have time and oppertunity I think many people would like to hear that gas reaction. 🙂
How is the engine idle with theese lightweight flywheels? Is it running smooth even though it’s just about 650grams?
sx3-swe heeft het onderwerp Speedometer / kilometerteller aangemaakt in het forum General questions 6 jaar, 11 maanden geleden
Hello,
My Ciao doesn’t have any speedometer or kilometerteller, but I would like to install one.
Are theese all the parts needed:
– Aandrijver, same on MIX and P? Or is Mix 16″ and my wheels are 17″ so it will give wrong readings?
https://www.jmpbonderdelen.nl/vespa-ciao-si/mechanisch/kabels/telleraandrijver-vespa-ciao-mix-origineel.html -
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 6 jaar, 11 maanden geleden
Did a small “service” on the daily today.
The brake light switch was broken, found a new one on JMPB, not listed for Ciao, but for Tomos.. But it was the exact same one as original, so I’m happy. 🙂Also replaced the brake handles, the old ones were rusty..
I tested with a 68 JET today, it felt a little bit stronger on bottom end, but wasn’t…[Lees meer]
sx3-swe reageerde in het onderwerp GZ: remnaaf/remdeksel voor, 5-spaak in het forum Onderdelen gezocht 6 jaar, 11 maanden geleden
Updated, stil searching for parts. 🙂
sx3-swe heeft het onderwerp Malossi Remsegmenten aangemaakt in het forum Overige techniek 6 jaar, 11 maanden geleden
Found theese today, are they new on the market or old?
I have ordered a set for front and rear, lets see how they perform. 🙂Couldn’t any info here on VCNL, any one have tested them?
(It’s Okey if you write in Dutch, I can translate it, hence put this topic outside english section)
sx3-swe heeft het onderwerp GZ: remnaaf/remdeksel voor, 5-spaak aangemaakt in het forum Onderdelen gezocht 6 jaar, 11 maanden geleden
Hello,
I’m looking for the brake shield for the front aluminium wheel of 5-spoke banana rim.
Got any? 🙂 -
Installed the Citypower exhaust now, and it pulls alot better now.. Used “Speedometer GPS” APP and it recorded 68,25km/h… I Think the engine would benefit from a lighter flywheel.
The spark have some white spots, I think a 68 sproier would be needed.
sx3-swe reageerde in het onderwerp Clutch service? in het forum General questions 6 jaar, 11 maanden geleden
A bit rusty inside… Lubricated it a bit with oil and now it runs much nicer.
But I think it would be good to replacesome parts inside of there.
sx3-swe heeft het onderwerp Clutch service? aangemaakt in het forum General questions 6 jaar, 11 maanden geleden
Min koppling gör några konstiga ljud, det gör det ett tag när det går tomt för sig själv om jag hjälper till att generera ljudet i videon
Vilka delar ska jag ersätta? Is it the needle bearing or should I ditch the whole clutch 😀 -
Installed the Original uitlaat instead, had to put some shim-rings in the rear here too, and take a bit longer screw. And then I fired it up and went out for a 7km tour, it performed quite good but it lacks the bottom end power. I hope that the Gianelli exhaust will give a bit more bottom end torque.
I think the original exhaust didn’t really let…[Lees meer] -
I tried installing the Gianelli original power, but it touches the gear for the pedals. I think it’s because I have 80mm polie, and the engine should be more in front.
Should the be a distance ring/shim ring on the rear exhaust mount?
