sx3-swe reageerde in het onderwerp Which vario gearing ? in het forum Pub talk 10 jaar, 6 maanden geleden
The Malossi gearing is quite long, especially in combination with 90mm rear disc. I think you will experience lack of acceleration if you go 90mm+1:9.
Meanwhile, the CIF gearing isn’t best quality.
I’d say you should try 1:10,5+90mm or 1:9+100mm -
sx3-swe reageerde in het onderwerp cut crankshaft in het forum General questions 10 jaar, 6 maanden geleden
3½ years later 😛
sx3-swe reageerde in het onderwerp Correct weight rollers for my set up in het forum Pub talk 10 jaar, 6 maanden geleden
What ratio do you have in your rear hub?
sx3-swe reageerde in het onderwerp Italkit krukas in het forum Krukassen 10 jaar, 6 maanden geleden
Anyone tested theese cranks? I must say the Full circle is very cheap to be a full circle crank..
What is the intake duration of the normal crank? Anyone have measurments? -
sx3-swe reageerde in het onderwerp What are theese Parts worth? in het forum General questions 10 jaar, 6 maanden geleden
English would be appriciated guys, google translate is quite bad at dutch grammar 😀
“new” is a relative state, I can also see wear on the parts, given though they are 27-28 years old it might not be that uncommon they got some dents after all theese years.. I think the Fabrizi kit have been assembled once, but not started..
My pinasco have…[Lees meer] -
paul99 :
http://www.tradera.com/profile/items/192192/herbie-53De Zweedse ebay
Haden’t see that, thanks 🙂
I found his other listing at “blocket”, not auction site, just normal listing site.
He lists much more parts.http://www.blocket.se/stockholm/Ciao_piaggio_trim_satser_samt_delar_simonini_60438678.htm?aw=1
I got some PM’s with bids, I must clarify that theese are not my kits.. I found them in Sweden and was looking to get info on the value on them only, and what they usually go for 🙂
Heres a picture of the Polini 42
Me too, thats why I asked what they would be worth paying for? 🙂
Here are pictures of the kits.
Thoose parts are old, and jMPB donät sell them 🙂
I think the crankshaft is stroked, hence why it’s 90cc? -
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 10 jaar, 6 maanden geleden
Okey, so I started to CAD up the rotor, first is according to HPI how the rotor SHOULD be, and the next is how the rotor ACTUALLY is, as you can see, the rotor is out of spec. 🙁
I will send HPI an email and complain about this, I will try to save the rotor by remachining it anyway, if HPI wats to send me a new rotor I will be happy!
Here is the diagram of the Rotor, will need to Cad it up to calculate the change of cone to lower it 2mm. 🙂
ROTOR SIZESA 17.00mm
B –
C 5.5°
D 4.5mm
E 33mm
Got theese photos from my friend… Yet have to pick it up and test fit, but we do have a mockup 🙂
For 3D printing, we made it a 2 piece fan that we’ll glue together, the final…[Lees meer] -
Yes, I have read Warooms thread, it’s very interesting and he is very creative!
The inner-rotor used there is much smaller, why building a decent fan a bit easier.. the HPI is BIIIIIG, the rotor have a bigger diameter (62mm) than the Malossi/selettra, which is quite big aswell..
Both the malossi and the HPI will have bigger inertia and will not…[Lees meer] -
sx3-swe reageerde in het onderwerp Malossi MHR Engine in het forum Pub talk 10 jaar, 6 maanden geleden
there are som options:
1. LC KIT
2. Electric fan, installed in the frame somehow.
3. Build your own flywheel/fanThis is how I will solve it:
http://www.vespa-ciao.nl/forums.php?m=posts&q=34070This weekend if I’m lucky, I wilol 3D print a mockup to see how it fits 🙂
That is a bit sneek version of the bigger HPI ignition, you can compare the CDI curves here:
http://hpi.be/item.php?item=210K221 (The one you saw)
http://hpi.be/item.php?item=068K221 (The bigger one, as I will use)Did he have a fan installed, or did he run with the rotor as is? What was his setup overall?
The problem is that you will not be…[Lees meer] -
Millen lever fortfarande 🙂
I’d say that the Malossi requires less modding to the MHR cracnkcase, due to it already have the DEPS port and was made for the crank case. have you already bought the reed case? I’ve read here that the new generation of the reed valve isn’t as good quality as the old ones.. Maybe consider a polini SE?
Peopple…[Lees meer]
Well, I’m curious to 😀 I think it will run quite good, if not atleast it’s unique 😀
So my engineers have looked at my fan, and due i the circumstances, it wont get much better than this.. I will 3D print a mockup as soon as I find time to visit my friend!Anyway, I made an EVO-2 of the fan, it means it’s 3D solid, te first one were just…[Lees meer]
Here is the version 1 of my cadded fan.. It should fit inside the carter and frame 🙂
sx3-swe reageerde in het onderwerp Different color of CDI unit in het forum General questions 10 jaar, 6 maanden geleden
Thanks 🙂
Thought maybe some were for 25 kmh and others for 45kmh -
sx3-swe reageerde in het onderwerp Pinasco vs Simo Cylinder head in het forum General questions 10 jaar, 6 maanden geleden
Thats for your input, I beleive I wasn’t clear in my original post.
I’m not looking for performance in horsepower or such.
I’m looking for a head with best cooling performance 🙂The reason is the HPI inner rotor that I will use is uite big, so it will be a bit hard to achive a good designed fan that can cool the engine properly, so I was…[Lees meer]
@De Brandweer, I will consider it, but I want a working fan for it first 🙂
Anyway, I took my time yesterday to mod the carter + ignition..
1. I put the adaptor plate for the stator and put it in the lathe and reduced the inner diameter so it matches ut with the stator inner diameter. Because I will need to clear the cooling lines in the…[Lees meer]
:: sx3-swe
