sx3-swe reageerde in het onderwerp CDI – 2/4 coils, cables in het forum Pub talk 10 jaar, 5 maanden geleden
Well, thats a bummer 🙁
I was thinking of putting this motor in a C24 ciao, And get everything to work with it.. I will look at selling it and looking for a new motor 🙂 -
But then I won’t have any low/high power on koplamp och brakelight I guess? Because everything is same voltage on the moped?
Hmm, my stator don’t have any brown, only 1 yellow, which is powered by 3 coils in series, the coils are not individual as they are on other stator, which have blue+brown.
I realize that the other stators have different thickness of copper wires on different coils, look at above picture.. Thinner wire will give more laps around the holder…[Lees meer]
Thanks,
I understand the difference in voltage.
But the position of the coils on the stator, that doesn’t matter right? As long as right cable is connected to the right coil? Because my taped coil have different position than other pictures of 4-coil stator.my other 3 coils are connected in series together, then only a yellow cable.
The…[Lees meer] -
I have no clue to be honest, the crank-case have many piaggio logos on it.
Also the flywheel have piaggio logo and some “Patent, made in the USA” or something similar, I can check tonight.
Is there any other sign I should look at?It might be possible that this engine is from a “baghee” the indian version bravo, made under piaggio license..…[Lees meer]
sx3-swe reageerde in het onderwerp Cylinder cover? in het forum General questions 10 jaar, 5 maanden geleden
I have no bike for the motor at all 🙂 Just bought the motor.. I’m used to the 6 cable version, thought first this was a 2-coil ignition but got surprised when opened it and it was 4 coils inside..
I have looked for the schematics aswell, haven’t found any. will look closer tonight how all the oils are connected
okey, but I only have 4 cables total, Green, Red, White, all of them goes to CDI unit.
Then I have only 1 left, which is 1 cable shoe in plastic housing, + ground attached to the carter..
So 2 cables are missing, I need to “lod” them on to the 2 coils? -
sx3-swe reageerde in het onderwerp GZ: Shipping a Vespa to Sweden in het forum Diensten aangeboden/gezocht 10 jaar, 6 maanden geleden
sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 10 jaar, 6 maanden geleden
Took some better pictures of the fan inside the carter:
Wilk1985 :
Impressive work! I had the same problem with this vliegwielkap, the brand is equal but they are not so equal in comparison with the original kap 🙂Thanks! I will try to get my hands on a original vliegwielkap and try with that! 🙂
@zevenenergie, thanks!
That green fan is only a mockup, only for testing the fitment and make…[Lees meer] -
Today was mockup testing day!
The fan fits nicely between carter and stator!
Unfortunatly the rotor went bad when machining it, milled it to hard in bottom when trying to make space for even more lowering.. So I’ll need a new rotor, and a lesson is learned and was quite educatble slicing up the rotor, quite interesting build!JMPB didn’t have…[Lees meer]
sx3-swe reageerde in het onderwerp Lennaert zijn rommelpagina in het forum Projecten 10 jaar, 6 maanden geleden
Nice set of parts you got there 🙂 So you found your Pinasco flywheel after all? =)
Is that the Pinasco kruk, where the hole have been stuffed with a kick-part?
Both carters are elc? Or CP? =)Looking forward to see your build!
sx3-swe reageerde in het onderwerp TK: Diverse vario onderdelen in het forum Onderdelen aangeboden 10 jaar, 6 maanden geleden
What ratio is the hub? 1:13, 1:12,5, 1:10,5?
That is correct, however i want a not stolen frame With intact chassinumber!
I think I wasn’t clear enough, I have not a certain vespa in sight at the moment..
My plan is:
1. Find someone who can help me
2. Together we look at marktplaats for a good object near you
3. I make moneytransfer and you buy the ciao
4. you take down the ciao in some pieces and pack it according to weight, info from TNT-post/PostNL
5. you…[Lees meer] -
sx3-swe reageerde in het onderwerp TK: RV-Simonini-Fabrizzi in het forum Onderdelen aangeboden 10 jaar, 6 maanden geleden
150 ex for the RV
sx3-swe reageerde in het onderwerp Which vario gearing ? in het forum Pub talk 10 jaar, 6 maanden geleden
Nice, but how about the last two gear? 12/30 and 44, they seem to have Pinasco numbers? I can’t find any Correlating numbers of teeth on the Piaggio sets, according to the chart. ?
It’s quite easy..
Column #1 = brand
Column #2 = Where to find, (model/country or sold as kit)
Column #3 = Are teeth angle cut or straight cut
Column #4 = The ratio of the gearbox
Column #5, 6, 7, 8 = Number of teeth on the gear, starting from the shaft that the clutch attaches to.
Column #9 = No idea actually.
Column #10, 11, 12, 13 = I…[Lees meer] -
Sorry for highjacking the thread, buti s all the internals different between 1:10,5, 1:12,5, 1:13 and so? Or is it for example only the main shaft for the clutch that differ between the ratios?
There are plenty of single gears on Ebay, but how to tell which will fit?Is there any any chart availble that describes the relation between number of…[Lees meer]
:: sx3-swe
