sx3-swe reageerde in het onderwerp SX3's Ciao perso [English] in het forum Projecten 7 jaar, 7 maanden geleden
I agree, always Nice to see The result between each run.. 🙂 we have now knocked The piece out and re rigged it for The back side.
If we would have had more time, we would have made 45 degree chamfer on each edge in The CNC. It would have been sexiest, but now we will do it by hand instead
A little more progress, still not going fast 🙂 it is “only” The back side left
1 hour later…. Now we will fine cut with smaller mill.
Taking alot of time, there is plenty of optimization possibilities though.
Work in progress, took about 3 hours to setup The tool path, now we have been running The machine for 3 hours. Still alot left, hopefully well be able to finish today..
The final version of the fan!
– Fins are directed the opposite way
– Made the centre part as a solid, due to tool size of the mill.Tomorrow we’ll be milling out the fan!
The corpse have served me well also, first 3D model is taking shape. I’ll need a Honda CR85 Ree valve as a donor so I can adapt the reed fitting.
sx3-swe reageerde in het onderwerp TK:RB racing parts & Doria clutch in het forum Onderdelen aangeboden 7 jaar, 7 maanden geleden
Edit: Just realized this was a group buy and not you items for sale, sorry for that!
About 3 years since last update!
The Ciao is still in the barn, awaiting to mature. 🙂I bought a house 2½ years ago, and I haven’t had much time over for hobbys.. hopefully I will have more time now. 🙂
So finally the piece of aluminium arrived, its T7075. I bought material enough for 2 fans because I know that when I and the CNC operator have…[Lees meer]
sx3-swe reageerde in het onderwerp Is this motor with marking D9x7 restricted to 25km/h in het forum General questions 7 jaar, 7 maanden geleden
SOrry for borrowing the thread, is there any difference in cylinder ports or piston-pin between Snor/Brom?
sx3-swe reageerde in het onderwerp GZ: Ciao 2005/2006 in het forum Brommers gezocht 7 jaar, 7 maanden geleden
Is 449€ expensive in your eyes? You think it’s possible to haggle/bargain over the price?
https://www.marktplaats.nl/a/fietsen-en-brommers/snorfietsen-en-snorscooters/m1309832856-vespa-ciao-25km-snorbrommer-nette-staat.html?c=9b26ed2a557deff636f4f8b9c5b7a618Its the only one on Marktplaats willing to ship to sweden 😀
sx3-swe heeft het onderwerp GZ: Ciao 2005/2006 aangemaakt in het forum Brommers gezocht 7 jaar, 7 maanden geleden
Hi,
Looking for a complete late model (2005/2006) ciao in “Nette staat”.
The thing is that you will need to ship it to Sweden, but I will cover the costs!Send me a PM with info of what you got. 🙂
Regards
sx3-swe reageerde in het onderwerp Rear vario clutch setup in het forum General questions 7 jaar, 7 maanden geleden
Well to be honest the Ciao isn’t even build yet, hence not tested! Probably I won’t be finnished in the upcoming 5 years with my speed either. But building is fun to 😀
My goal is to have a combination of acceleration and speed.
I don’t want to do wheelies by just touching the handle but also I’m a bit of a pussy, so 85km/h+ on a ciao I’ll…[Lees meer] -
sx3-swe heeft het onderwerp Rear vario clutch setup aangemaakt in het forum General questions 7 jaar, 7 maanden geleden
Hello,
I’m a bit buzzed about the gear ratios, and size of pulley on the rear clutch and would appriciate some input from you experts.
This is my setup:
Polini front vario
1:11,5 rear varionaf
100mm pulleys on rear cluctch
Yellow springs inside clutch
Pinasco 46mm
21mm dellorto.
CalibrataSo back to the topic, from what I’ve read 90mm disc…[Lees meer]
sx3-swe reageerde in het onderwerp Tiesman perso in het forum Projecten 7 jaar, 7 maanden geleden
Thanks for the info, at 290€ for the clutch + 70€ for the bracket + shipping thats a hefty price 😀
Is there any benefits using the Doria clutch vs Fox-mod clutch? -
Nice! Have I (google translate) understood correct that with this vario-clutch kit there is no need to replace the vario axle to the Fox-mod?
And the belt should the Malossi, made for Honda Wallaroo.
Where do we buy it? 😀
sx3-swe reageerde in het onderwerp Big Deps Vespa Ciao 100cc simonini citta in het forum Projecten 7 jaar, 8 maanden geleden
Nice build Robert!
Is that a Puch Maxi EBR fork you’ve used?
Did you reverse front velgen so the hub is on left side instead of right side?If you have more pictures of the discbrake setup it would be nice to see more of that. 🙂
sx3-swe reageerde in het onderwerp INT: HPI Vliegwiel voor Koeling in het forum Onderdelen aangeboden 7 jaar, 8 maanden geleden
Hi,
Sorry I didn’t realise this was the marketplace of the forum, thoought it was normal discuss thread! My bad!.
@Martino, this fan is printed in 2 pieces and glued together with hobby-glue (as shown in the perso). It’s only intended as mock-up for testing fitting. I don’t think it will handle real-life use due to the heat.
Notice that I have…[Lees meer] -
Anyone manged to get a fan for the HPI?
I have lowered the stator maximum, and milled of the top of the rotor aswell.
(In the Perso, it’s the old rotor that i fucked up)Attached pictures is the new rotor, originally for Puch, but I modded the cone.
I have put a ruler on the…[Lees meer] -
sx3-swe reageerde in het onderwerp C31 vs C24? in het forum Pub talk 10 jaar, 5 maanden geleden
Thanks for the info..
I’m curios to know why there was a C24 and a C31 sold at the same time, what was the idea of that?
Would be cheaper to have only one model in the production line.. -
sx3-swe reageerde in het onderwerp CDI – 2/4 coils, cables in het forum Pub talk 10 jaar, 5 maanden geleden
In Sweden, all the vespas are “snor”, 25km/h.. Therefor all have this plug in the intake.
The ciaos never came with license plate here, that are allowed for 45km/h
With a dremel it would be a hassle, but putting it up in the mill it will be quite easy 🙂
To be honest, I mainly bought the motor for its elec ignition and the original vliegwiel…[Lees meer] -
sx3-swe reageerde in het onderwerp Bearings in het forum Pub talk 10 jaar, 5 maanden geleden
The simo kruk is stroked I beleive, 44mm instead of 43mm, is your cylinder ports adapted to this stroke?.
You will be better/cheaper off using the Mazzucchelli full round kruk, AMT206, JMPB sells this one. It’s almost same as Malossi full round kruk.
6202-C3 is on the flywheel side, due to higher load, lets the metal expand a but more due to…[Lees meer] - Meer laden
:: sx3-swe
