Seru.ch reageerde in het onderwerp 50cc snel enduro cilinder in het forum Motorisch 4 jaar, 6 maanden geleden
Is the piston mounted right?
The Arrow on the Piston must show to the exhaust. -
Seru.ch reageerde in het onderwerp Sproeiers Ali expres in het forum Afstellen 4 jaar, 11 maanden geleden
Hy Martin
I have also ordered Sprinklers on Ali and I have measured them. I was also sceptic.
All of them was the printed size +- 1 size. per example the 65 was measured 66, but that can be a measurement error, I was not able to measure particulary and the error of +- 1 can be my fault. The Dellorto I have measured to compare was also +-1 size. -
Seru.ch reageerde in het onderwerp Vario wil niet afgesteld worden in het forum Vario 4 jaar, 11 maanden geleden
Dieses:
If you have this mounted, trow it away. This is a restrictor.
Do you have mounted the Rubber-ring that comes with the Malossi-Vario? That are a restriction and not must be mounted.
Seru.ch reageerde in het onderwerp Carburateur past niet? in het forum Problemen oplossen 4 jaar, 11 maanden geleden
The ring that Martino asks is like a thick O-ring behind the white bushing and prevents airleaks.
You have confirmed, that you have ha 12/10 for catalizet models and this have a special bushing with 19mm outer diameter instead of the normal 18mm (like your 13/13).
Example of the…[Lees meer] -
I think your 12/10 is a carburatore for the katalizet engine. Can you interchange the Nylon bushings? In other words; can you put the bushing from the 13/13 into the 12/10 and the other way?
What are the inner diameter of the bushings of the carburators? That must be 15.90 to max. 16.10mm.
Don’t screw to strong the Holder of the carburator, that…[Lees meer] -
Seru.ch reageerde in het onderwerp Venturi Cone carb in het forum Motorisch 5 jaar geleden
With bether Pictures and more details :
https://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?t=75834
Seru.ch reageerde in het onderwerp Stuurslot Vespa Si in het forum Overige techniek 5 jaar, 1 maand geleden
Look at jmpb for a lock from Gilera Città or Tomos A35 and compare the measurements.
A vew Vespas (the scooters) have the same lock, but vespaparts are very expensive. -
Seru.ch reageerde in het onderwerp Pinasco powercasing in het forum Kroeg praatjes 5 jaar, 1 maand geleden
Look this movie and you buy a Malossi instead of the Pinasco :
Seru.ch reageerde in het onderwerp start/blok probleem!? in het forum Motorisch 5 jaar, 1 maand geleden
I hope you can translate this, that you can understand:
Kontrolliere ob der Pfeil auf dem Kolben Richtung Auslass zeigt. Wenn der Kolben um 180 Grad verkehrt montiert wurde, entstehen die gleichen Symptome.
Ich würde auch auf eine 52 bis 56 Düse probieren. 46 ist bestimmt zu klein.
Falls der Kolben richtig eingebaut ist und mit einer ~52er Düse ni…[Lees meer] -
Seru.ch reageerde in het onderwerp Tonni's CandyRed Ciao in het forum Projecten 5 jaar, 2 maanden geleden
I have the same flywheel like you, with the same problems. I don’t see this marks, till I read your post.
I have measured the Pinascoflywheel an a original one to compare it.
The issue with the ignitionpoint you can resolve making the holes in the Stator to slots and file down some places in the Carter. I can send you a few fotos.
The first curve…[Lees meer] -
Seru.ch reageerde in het onderwerp Zelfbouw uitlaat topic in het forum Uitlaten 5 jaar, 2 maanden geleden
You can download the book here :
https://www.mopedarmy.com/wiki/Category:Performance_Tuning
Look at the Book of “Graham Bell”, page 70 to page 92.
At page 90 that have a exemple of a Racing muffler for low noise. -
Seru.ch reageerde in het onderwerp Minimale stroom in het forum Elektrisch 5 jaar, 3 maanden geleden
Stellen Sie die Verbindung folgendermaßen her:
Was für eine Zündspule (Hochspannung) verwenden Sie? Wenn es sich um ein billiges Remake handelt, empfehle ich Ihnen, ein hochqualitatives Remake zu organisieren (Kosten ca. 30 €) oder eines zu verwenden, bei dem ein anderer Motor läuft. Diese remakecoil sind von sehr geringer Qualität. -
I think you have a Short-circuit between the Flywheel and the coil. The connection of the coil is not ok, the space between the Flywheel and the coil is very small.
I see that you crankshaft is damaged and the thread is broken. The rear fixingpoint of the Case is also broken. How will you use this Engine?
Seru.ch reageerde in het onderwerp Cilinder rubbers in het forum Motorisch 5 jaar, 3 maanden geleden
The 3 smaler pieces Co. s to the side of the cylinder. Normally that AR 4 pieces. The larger Piece is for the Ciaohead, normally 2 pieces.
Seru.ch reageerde in het onderwerp Decompression valve in het forum Problemen oplossen 5 jaar, 3 maanden geleden
0,5 bar ist es auch OK, ich glaube nicht, dass der Druck im Gehäuse 2 bar erreicht, wenn der Motor läuft. Aber mit 2 bar sind die Blasen größer. 😎
Die Dichtung der Kurbel springt bei mehr als 4 bar heraus. 😀
It’s bether to make the Test without the ignition, so you can check the Crankseal too. -
I try to explain better.
When you make a leak test the air go’s thru the small hole (blue arow) and ends behind the valveseat (yellow arow). To make the sealtest you must close the small hole or keep the engine under pressure during the test with a compressor (1-2 bar). So you can test all seals without desasembling the engine again.
The Valveseat…[Lees meer] -
That leak is normal. The air coms true the little hole in the cilinderhead and ends behind the valveseat.
When you whil make a leak test you must close this hole between the head and the Cylinder. You can do this with a self made headgasket without the small hole. After the Test change the headgasket wit the normal one.
When you Maka the leak rest…[Lees meer] -
Seru.ch reageerde in het onderwerp Wat is de snelste manier om een Vespa Si in een stationwagen te krijgen in het forum Problemen oplossen 5 jaar, 4 maanden geleden
That’s my way, but is for longer transfers to tours:
:: Seru.ch
