Piet30 reageerde in het onderwerp Piet's Kick start Ciao in het forum Projecten 17 jaar, 5 maanden geleden
Hey Edjuh; I know you are a oldtimer fan too.;)
What do you think about my front carrier?
Piet30 reageerde in het onderwerp malossi springs in het forum General questions 17 jaar, 5 maanden geleden
mmmhhh, after ma experience the yellow ones are the weakest.
I think that the Polini Top One could fit the 70er Ciao because I drive a Proma Cirquit on my 70er Ciao and the fixing should be the same. But if you also have the 19″ wheels like I have you could get a space problem to your front wheel.
see pics
cu,Ralf
@ Hansieb: you say it man;)
short update.
The kick system is working now. I have put in new wheels, handlebars, front and back carrier and polished the old painting.
The carriers allow a lot of capacity for the ZZT09 =)
Also the gear ratio is installed now. It is a 10,5 :1 gear with 83mm pulley and 55mm diameter clutch bell. Dat…[Lees meer]
Piet30 reageerde in het onderwerp Hallo erstmal ^^ kortikevin schaut mal rein. in het forum Algemeine fragen 17 jaar, 5 maanden geleden
ik snap dat nit :haha
so, kick system and engine is installed.
But it looks that the chain is a little bit to long. Maybe I need to cutt off 2 or 3 chain links.
What would you say? Are 2 chain links short enough?
cu,Ralf
Piet30 reageerde in het onderwerp FonS – 19 inch Ciao in het forum Projecten 17 jaar, 5 maanden geleden
ui, what a mooi old Ciao:thumb
from the history I could say that the first Ciao were delivered from Italy beginning 1968. This Ciao all had 19″ wheelen. There were two models at that time with different forks. One model with spring fork like yours and one model with fork without springs and wheel brake like a real bicycle.
I have a 1968 Ciao…[Lees meer]
Piet30 reageerde in het onderwerp Piet's SimoPinasco Brommer in het forum Projecten 17 jaar, 6 maanden geleden
joha, today was first run :whistle
after some start problems I put off the airfilter and injected some Start Pilot. Then first noises started
[url=http://de.youtube.com/watch?v=d2vD-cYEpX0]first noise[/url]
then after fixing the airfilter again the RPM equalized
[url=http://de.youtube.com/watch?v=nd30W-RqwH4]low…[Lees meer]
today I fixed the foot rests, side stand and back lamp=)
Tomorrow the bracket for the head lamp will be finished and then I try to start the engine :rules
cu, Ralf
Michel :
This kind of airfilter are not very good in filtering.
A spongefilter is better Piet. Better filtering en more capacity. 😉I think your headlight will look better just in the middle of the 2 positions if that’s possible.
So under the steeringbar and just on top of the lower forkmounting.
If that’s not possible, take the first… -
Piet30 reageerde in het onderwerp is that a Polini cylinder ? in het forum General questions 17 jaar, 6 maanden geleden
aha, I think bevore I separat the engine I will try how it runs with the Polioni cylinder first. Would the top speed be in the same range like with a DR EVO in that carter and the same setup?
cu,Ralf
yes I think so, I have the feeling that the 46mm and 46,5mm cylinders are not high RPM wonder. My 43mm Pinasco is a rocket compared to my 46,5mm Malossi.
Also I have one engine with the 43mm DR EVO what runs like hell.:bier
cu,Ralf
is this cylinder a racer or should I change it with a 43mm DR EVO ?
cu,Ralf
VespaAvanti :
Nice:thumbI think position 2 is the best for the lamp;)
Where have you buy that aircleaner?:?
the airfilter is from a Scooter Shop named Mopshop (www.mopshop.de)
this is the link :…[Lees meer]
so, short update.;)
The exhaust heat bands are ordered:thumb
Malossi clutch springs, brake and gas cables, fuel line and filter and the headlamp were delivered yesterday and fixed now.
I only don’t have the Deko cable, no idea where to get at the moment.
In the following pics I’ve tried to find a position for the headlamp. On top of…[Lees meer]
Piet30 reageerde in het onderwerp BisschenMüde ist jetzt auch hier in het forum Algemeine fragen 17 jaar, 6 maanden geleden
wow, 17″ würden mir sehr gefallen=)
cu,Ralf
Piet30 reageerde in het onderwerp Jordy.s toer ciao in het forum Projecten 17 jaar, 6 maanden geleden
OrangeCiao :
:Ddan kan ik de poorten niet door trekken 😀 snapiethen I can’t the poorten not flush out snapie :d
Dein Engels is beter dan mijn Dutch:thumb
For plug and play je hebt gelijk. Have goed slagen.;)
Tell me if my Dutch makes sense.:haha
cu,Ralf
hey, looks like a nice project.:thumb
But why do you want to use a nice Speed Engine groote carter helft to make a Simo Zij inlaat ?
For that you can use every standard inlet carter as you need to close the inlet anyway. Possibly you can use one with demaged inlet window. Sometimes you you can get that for free=)cu,Ralf
Piet30 reageerde in het onderwerp Simo side inlet + Pinasco in het forum Pub talk 17 jaar, 6 maanden geleden
Vincent :
nice engine indeed! Do you plan to cut a bit of your cilinder or not? (The piece that blocks half of your inlet)Only isn’t there a better way to block your standard inlet? This looks a bit crappy:con
tädää, nice yellow inlet blocker.
cu,Ralf
hey BisschenMüde, das sind 10 spakers, die haben 16″;)
cu,Ralf
Piet30 reageerde in het onderwerp Howto: Krukas tuning berekenen in het forum Oude topics 17 jaar, 6 maanden geleden
wow, what a great how to do :thumb
I just skimmed everything and find out that I understand more and more your language.
One thing is not clear for me. Could you tell me what a Brom Krukas and what a Snor Krukas is?
In what engines could I find this Kurbelwellen?cu,Ralf
:: Piet30
