Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 16 jaar, 3 maanden geleden
that’s my Ciao with frame number M7E1T 04013497
I bought it from the first owner with keys and original papers;)
Only changed the exhaust and Benzin kran:D
nice Forum:D
want to show my old Ciao Moped with frame number: C9V1T 28050
I have checked the frame number again and it is like written. 😕
The buildyear is 1968
Piet30 reageerde in het onderwerp Piet's Ciao "A" in het forum Projecten 16 jaar, 3 maanden geleden
miniciao, das ist klasse:thumb:thumb:thumb die Ciao ist also 1968=)
dunkel grün oder grau wäre auch meine Farbwahl. maybe Amazonasgrün 340 😉
Thanks a lot
hey, and edit just saw the link to the oldtimer forum here. Haven’t seen that before. I will take some time tomorrow to read something in that:D
wow, so many mensen here who like old Ciaos, fantastic:thumb
after I was lucky to eliminate the black color on the handlebar there was a red color under the black:boos
Put more Grafitti remover on, and schwups it looks like real handlebar;)
The chrome is a little corroded but better than painted I think.
Jelle, I got this…[Lees meer]
so, just checked the engine and it is a newer model Moped engine with 11,5mm inlet.
The minus clamp is screwed with one of the blok screws and the Aluminium casting has a rough structure.
But I found a right version one in my fundus:D
This engine is also a Moped engine and has the minus clip riveted to the blok. Also the Aluminium…[Lees meer]
FonS, you are right. I will just go and check;)
Piet30 reageerde in het onderwerp FonS – Perso in het forum Projecten 16 jaar, 3 maanden geleden
wow, that is a great idea:thumb
what carb will you put on that nice thing?:)
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 16 jaar, 3 maanden geleden
ah Edjuh, it looks that your twin will get much power.:D
Interesting to see the twin growing.
Piet30 reageerde in het onderwerp Piet's Off Road Bravo in het forum Projecten 16 jaar, 3 maanden geleden
Docs, I also do not know what I’m doing and if it will work:lol
Will keep you updated on the details I’ve planed.Edjuh, yes will try to weld a bracket to the frame for the damper fixing. Some people think that the damper need to be fixed in an angle to the supframe and not vertical. Need to check how I can do that.
How is your Bravo…[Lees meer] -
soho, got some nice infos from Lowie about his monoshock on his Si :thumb
Today I fixed the Si subframe and measured the hight for the mono damper
Need to find out on what position I could fix the damper 😉
looks not bad I think
I already have ordered this nice damper from an ItalJet
ja,ja,ja, I took this exhaust from my son because it was just laying next to me when I wanted to run the 50ccm KickSpeed for the first time.;)
I will change it to a Leo Krul when I start to find the right setup for that engine. Maybe there will be some other changes after having the first ride with the big vario clutch 😀
hehehe, is no Super Bravo, only a simple Bravo with some extras:D
Today I visited Sil :bier and got a nice Si kick brug. As some of you already told me, that brug is much stiffer than the Bravo one
here the comparison
also the Si brug is about 4cm longer from front fixing to rear spring fixing point
and the Si brug…[Lees meer]
Piet30 reageerde in het onderwerp Piet30 first Moped in het forum Projecten 16 jaar, 3 maanden geleden
G-no, yes not the right fenders. I fixed this fenders from a Ciao SC when I was 16 years old and they are still fixed. Also the sadle cover is from a Peugeot, again I will keep it:D
And the small frog sticker on the head lamp is still alive too from 1977.;)Bas94, the Ciao SC was an old model in the 70th. It means “super comfort”. This model…[Lees meer]
today I got post from Speedbuxy. Thanks man:worshippy
Hope that will do the job.
Piet30 reageerde in het onderwerp Piet's Off Road Bravo in het forum Projecten 16 jaar, 4 maanden geleden
today I fixed the engine the first time and tried the kick drive by hand
[url=http://www.youtube.com/watch?v=guZpsfk8jfg]kick test[/url]
then fixed a carb and an exhaust from my son to start the first time:D
[url=http://www.youtube.com/watch?v=lCGrNgS_D8c]first run kickspeed[/url]
Now I will measure the length for the V-belt to have a…[Lees meer]
yeah, milling boost ports makes fun 😀
The exhaust port has a width of 25mm and a hight of about 16mm. Hight from the port to the deck is about 29mm. Outlet inner diameter is about 20mm. Wanted to weld a bigger outlet tube but have no possibility to weld it.:|I don’t have tested the gearbox with 1:8,5. No idea what the outcome is. If you say…[Lees meer]
so, it’s time to move forward with this:D
50ccm KickSpeed close to finish. Only need to assemble Ignition and cylinder head
1,5 mm gasket;)
cylinder reworked by 1,5mm
And I found one funny back light
Piet30 reageerde in het onderwerp Aachen [Oche Vespa Meeting] II in het forum Vespa-Ciao.nl 16 jaar, 4 maanden geleden
I will take care about next time.;)
ui, that’s why we were missing you:o
We were wayting of you and thought that you were catched by the Police, but now everything is clear. Yes it was last Saturday.
Damn,:boos
here some filmpjes from the last meeting on 21th
hope to see some of you guys next meeting;)
:: Piet30
