Piet30 reageerde in het onderwerp 2 gear Bravo in het forum General questions 15 jaar, 9 maanden geleden
bedankt man :bier
I was looking for it but could not find it.
yes, I thought so to modify the Ciao frame.
Good advice :thumb I will check Vincent’s perso
Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 15 jaar, 10 maanden geleden
mmmmh. no idea about year. I do not have papers for it. 😕
Miniciao, I have a new frame number for your list 😉
M9N1T 0105004
Piet30 reageerde in het onderwerp 50cc Cylinder and piston tunen in het forum Opvoeren voor gevorderden 15 jaar, 10 maanden geleden
ok, have made some more detail pics.
start with the holes in the piston that is basic for the cylinder
start milling the holes
milling the channels
pre milling the outlet to 20mm in tube area. Open the inner curve with a big grinding stone
grinding rest of big channels
and grinding round and…[Lees meer]
ok, here a pic from the outlet
and the tools with what I did the outlet window in the bore.
The big diameter for the window width and the smaller one for the hight
Piet30 reageerde in het onderwerp Piet's Ciao "A" in het forum Projecten 15 jaar, 10 maanden geleden
tädäää
und direkt mal eine schöne tour gemacht 😀
it should not be a high performance cylinder for 1200 RPM or so.
Should run fast with much power on a standard tuned Vespa block with 13 carb and Gianelli City exhaust
http://www.jmpb.nl/store/index.php?act=viewProd&productId=1013
try to make some outlet pics later 😉
so, the old Chromi was to noisy. Fixed a new one. Top Speed should be a little higher than 50 km/h now :duivel
Piet30 reageerde in het onderwerp oldtimer toer Noord-Holland in het forum Vespa-Ciao.nl 15 jaar, 10 maanden geleden
ah, there is a Oldi tour and I don’t have time on the 23rd. :boos
If you postpone it I maybe could drive with my 19″ Oldi
Piet30 reageerde in het onderwerp Piet's Ciao "A" in het forum Projecten 15 jaar, 11 maanden geleden
the frame number is on the right side above the chain
Piet30 reageerde in het onderwerp Oldtimer voorvork? in het forum Framedelen 15 jaar, 11 maanden geleden
I think it is a front fork and wheel from a Motobecane Moby M1. 😉
Next week when I will be back home I can make some better pics from my Moby 😀
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 15 jaar, 11 maanden geleden
very nice benzin kraantje. =)
Does it fit to the plastic fuel tank?
it rides like a kart, no swimming, pure road contact, absolute hard. Only suspension in the tires.;)
But you need to be careful with road bumps, that sometimes strikes very hard into the frame. If the road is nice it is a great and relaxing drive feeling, maybe also coming from the 19″ wheels.
nothing goes over the good old Chromi :rules
ok, will make the Chromi under this afternoon. 🙂
mmmh, maybe I will paint them green RAL 6019 combined with white. New Chrome can be expensive 🙁
it looks that the engine fits into the frame :thumb
Tomorrow it will make it’s first noise :rules
I got this stickers from Schellerhoff spare parts. This are replicas and could be ordered in many colores.
If there are more people interested in that type of sticker I could collect your requirements and make a collecting order to Schellerhoff.
If you want to try it by yourself, here the adress: Herbert Schellerhoff…[Lees meer]
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 15 jaar, 11 maanden geleden
Fotos from your 19″ Ciao in your garden? =)
Very very nice.
:: Piet30
