Piet30 reageerde in het onderwerp experiences with 9,5:1 CIF in het forum General questions 15 jaar, 5 maanden geleden
Hans, that is what I refering to 😉
because Dokter Motor had some rub off on the teeth.
He is thinking that the hardening or matriel of the insertes was not ok. -
Piet30 reageerde in het onderwerp Simo kruk and cyli in standard block in het forum General questions 15 jaar, 5 maanden geleden
oh, to late :boos
ui, is that so?
How can I see the different if a 48mm cyli need a 43mm or 46mm stroke?
Now it starts to become complicated. I thought there is a hook somewhere.
thanks for the infos. :thumb
Yes making a larger bore in the crank case for the cyli is no problem for me as I have a milling machine with the right equipment 😀
look you here
http://www.vespa-ciao.nl/forums.php?m=posts&q=22115
I think for the older 48mm cyli (3 fixing pins) I need a kruk with 46mm stroke, right?
So if you say that…[Lees meer]
Piet30 reageerde in het onderwerp Herfst meeting Thorn – 31 oktober in het forum Vespa-Ciao.nl 15 jaar, 6 maanden geleden
if the weather is ok I will come with my son Junior Piet :thumb
Piet30 reageerde in het onderwerp Polini LC kit on Polini EVO ? in het forum General questions 15 jaar, 6 maanden geleden
ok, just checked Peters special and it looks that he is driving a modified big Polini on the RV.
What about a 41mm cylinder on a RV or EVO engine? Does that make sense? 😕
wuhaha, sounds goil. 😀
Piet30 reageerde in het onderwerp Junior Piet's Simo side inlet in het forum Projecten 15 jaar, 6 maanden geleden
Ah, I know what you mean. That the bearing holes of klein carter and groote carter are not inline.
If they do not match I anyway don’t have a chance as the position of klein carter is fixed by the large carter sealing edge inside the main carter sealing. 🙁
I will put a krukas in during next days, then we will see.
Arvid, the milling machine is a very nice toy 😀
Sil, so far the quali of the Simo klein carter is ok. Only the cylinder gasket surface was 0,3mm below the gasket surface of the groote carter.
But I milled the gasket surface in one fixing and now it is perfect. 😉kijk je
Also milled the cylinder seat to diameter of 51,5mm for the…[Lees meer]
hope it will run, maybe you will see it in my son’s Ciao on the next tour :thumb
so far we only bought the 16er carb.
the cylinder set on an SE wich I bought for 70,- Euros and the Simo parts were dealed with other parts. Total amount so far less than 100,- I would say.
I would say that is low budget.:D
Piet30 reageerde in het onderwerp 11 Steden Toer 2010 in het forum Vespa-Ciao.nl 15 jaar, 6 maanden geleden
some Bilderchen 😀
Piet30 reageerde in het onderwerp What Membraanplaatset ? in het forum General questions 15 jaar, 6 maanden geleden
yes, that’s what I have heard too. What membraan thickness are you guys driving?
0,25mm or 0,35mm or even thicker on what cylinder ?
super filmpje. 😀
Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 15 jaar, 6 maanden geleden
hehe, thanks miniciao. :thumb
Dat is ma een mooi bijdrag. 😀
Andree, very well organized tour, but you should order better weather for next time. :thumb
It was a pleasure to drive with you all, my son was so happy driving his first tour with so many fast drivers.
Hope we will see you all again next year. 😀
will post my pics tomorrow.
so, Junior and myself will start in 30 min. 😉
See you guys in some hours.
Is there a service car where we could put our sleep sacks in like last time?
Piet30 reageerde in het onderwerp 11 Steden Toer 2010 in het forum Vespa-Ciao.nl 15 jaar, 7 maanden geleden
geld for Piet30 en Junior is ook overgemaakt 😀
:: Piet30
