Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 15 jaar, 4 maanden geleden
so, enlarged to 75,6mm. Kruk turns nice now.
Edjuh, that is my fear also. :'(
just enlarged the great carter to fit the Simo kruk.
The diameter of kruk is about 74mm, my carter has 74,5mm now. Do you think that is big enough or should I go for some 0,1 larger? 😕
Piet30 reageerde in het onderwerp Puch Maxi stroke? in het forum Pub talk 15 jaar, 4 maanden geleden
ritze, thanks for the infos :thumb
I’ve just ordered this one here for first trials 😉
http://www.jmpb.nl/store/index.php?act=viewProd&productId=1392
ritze, exactly that are my sick ideas :thumb
thanks guys. 😉
I got very very bad ideas now.
yeah, even with a 30mm CityPower should run well, maybe a double CityPower 😀
just1991, no Problem, I have many many of these. This are normal and C3 krukas bearings. Let me know how many you need.
Hey Olaf, yes the kruk looks good in that block. Thanks again to make that happen. :thumb
Jarco, yes there are many old bearings, maybe I can rip it up for decoration and sell it.:D
Defenitly want to ride that Ciao over the next year tour season, sure we will meet somewhere then.Edjuh, that will become a smooth tour racer I hope. Maybe I…[Lees meer]
update.
got my Polini race saddle
and this will bocome the place for my 12 Volt transformer for my RPM clock
but the best has also arrived, täädää, the 46mm Simo kruk
Just a little work on my milling machine and this biest will fit 😀
Piet30 reageerde in het onderwerp Waarom? in het forum Projecten 15 jaar, 4 maanden geleden
maaan, that is real clean, great stuff =) :thumb
Piet30 reageerde in het onderwerp FonS – Ultra Chrome Special in het forum Projecten 15 jaar, 4 maanden geleden
wow, that is a nice project. :thumb
Piet30 reageerde in het onderwerp De Nieuwjaarstoer 2011 in het forum Vespa-Ciao.nl 15 jaar, 4 maanden geleden
if there is no rain or snow the chance for Junior Piet and myself is very high to join you guys. 😀
that enlarges the ports more than having a cylinder wall there. :thumb
tnerual, the ports are a little optimized 😀
Some people do it like that, for example on this cylinder.Was that your question?
ritze, I hope it will not crack, keep your fingers crossed. 😀
100km/h ??? :'( I only want to swimm smoothly in the tour field with enough play room on the throttle handle.
Thanks for following my crazy plans.
Maybe that will be my last project.:D
Mike, I thought that a real toxic Yellow will be a good color. I even also don’t know if the covers will fit into the total picture. If not I can put them off and will have some 5 spaaks below.
Also I have ordered a Polini race saddle to get a deep seat position as…[Lees meer]
Piet30 reageerde in het onderwerp Junior Piet's Simo side inlet in het forum Projecten 15 jaar, 4 maanden geleden
Hans, no panic, Junior is no Nuckelchen. He is driving faster than 60km/h since he was 13 years. Also is a very good Kart Race driver in MSC Wipperführt.
He already drove the last 11 Steeden tour with 80km/h. Only lost his silencer and headlamp. 😀
Piet30 reageerde in het onderwerp Junior Piet's Simo side inlet in het forum Projecten 15 jaar, 5 maanden geleden
😀 maybe you can meet next year on a tour.
Junior is 15. He drove the 11 Steden Tour this year. 😀
wuhaha, that are all old bearings from engine I repaired, overhould or tuned. 😀
I have even so much old gasket on a hook on my wall.
just had some good time with my Junior at the workbench and finished the block. :rules
Junior will get wings with that as his weight is about 45 kg.
Piet30 reageerde in het onderwerp Herfst meeting Thorn – 31 oktober in het forum Vespa-Ciao.nl 15 jaar, 5 maanden geleden
how is the weather in Thorn at the moment ?
:: Piet30
