Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 15 jaar, 2 maanden geleden
just1991, your Dad is right. If you want to do it perfectly you need to add all weights of moving parts.
But that means, that I have to modify the new Simo kruk what is neutral balanced for use in our engines.
I’ve made the experience with a Muzzucchelli kruk and Pinasco flywheel (both also neutral balanced) that I have as good as no…[Lees meer]
(a)
today I milled the carter in the exhaust tube area to get enough space for the 30mm exhaust tube. 😀
Edjuh, that’s how it is. Hope this will work. :bier
geodguus, this is no special machine. This is the table of my milling machine. (I know this is flat 😉 )
I positioned two clamping blocks that the kruk and flywheel can turn easily without blocking. Thats all. -
as the Simo kruk is neutral balanced and the flywheel not, both together always turn with the ignition window to the top.
to get the flywheel also neutral balanced together with the kruk I pressed two pieces lead of about 9,5 gr weight each into the slots above the ignition window.
With that and a 8mm hole on the opposite side of the…[Lees meer] -
Piet30 reageerde in het onderwerp inner rotor ignition questions in het forum General questions 15 jaar, 2 maanden geleden
Ah, sehr cool, trains my Dutch =)
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 15 jaar, 2 maanden geleden
nice man 😉
update.
I got a KTM Brembo rear brake and it looks that it fits into the Ciao frame when I build a special bracket for the caliper and adapter plate to fix the brake disc to the wheel.:D
Piet30 reageerde in het onderwerp legal certificat Malossi TooBad? in het forum General questions 15 jaar, 3 maanden geleden
ok, legal may be was the wrong question. 😀
But this number like for example on a Sito should have a certication like the Sito. Has somebody seen that kind of homologation paper for the TooBad?
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 15 jaar, 3 maanden geleden
Arvid, thanks for the info, Iwill have an eye on it. 😉
The original Polini two membran has a thickness of 0,33mm. Do you think I have to use a different thicknes of the new membran?
Btw. what do you think about the bewerkt carter? Did I mill too much away or is it ok?
mmmh, I have not modified the ports, this is original Simonini
so, after discussion with Mofafreak and Mike from PMT I made some fine tuning on the EVO block
First milled the peak behind the membran case away in both carter halfs
Also the membran case has some potential
Free breathing 😀
Piet30 reageerde in het onderwerp distance cylinder studs Sprocatti in het forum General questions 15 jaar, 3 maanden geleden
aaah, assuming that a 2007 Simo has the same stud layout like the Sprocatti. Would a distance of 44mm from middle stud to middle stud be ok?
Or what is the distance on a 2007 Simo block?
Piet30 reageerde in het onderwerp Het grote "vespa oldtimer" topic in het forum Brommers algemeen 15 jaar, 3 maanden geleden
haha, you crazy Dutch man. This lamp, the V-stuurs and the 17″ high shoulder wheels were the reason to buy that stuff. 😀
Piet30 reageerde in het onderwerp Olliegasselt Polini 41mm LC , incl wp , vario in het forum Projecten 15 jaar, 3 maanden geleden
Oldtimer rulez :thumb
I got another two Oldtimers 😉
One is a rolling frame, complete without engine. Has a lot patina everywhere. When I sprayed a little brake cleaner on the back rim it looks very nice.
Also nice that this are 17″ high shoulder rims with about 7:1 gear box. =)
The front lamp is funny. I’ve never seen that style before.
The…[Lees meer]
Andree, is it ok if I use a 13 carb for your tours? That also would save fuel for me. :p
here you can see an add pic from the exhaust port. It still has the original strcture, not grinded.
also made a port map ouf the outlet
outlet timing is about 200°
only the inner diameter of the outlet tube.
today the seat for the cylinder enlarged
and fits 😀
Then the kruk assembled and see that there need to be a 2,5mm foot gasket
with 2,5mm gasket it also looks better on OT and outlet
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 15 jaar, 4 maanden geleden
and the small carter enlarged
Fits well :duivel
:: Piet30
