Piet30 reageerde in het onderwerp Oldtimer Toer de 2e editie in het forum Vespa-Ciao.nl 14 jaar, 10 maanden geleden
I’m not sure if my back can make it, maybe I can let off some air pressure from the wheels to make it more soft 🙂
Piet30 reageerde in het onderwerp VCT 2011 Editie: Texel in het forum Vespa-Ciao.nl 14 jaar, 10 maanden geleden
yes, I will buy him some nice jogging shoes in advance.:haha
but a towing rope is also not bad 😀
hahaha, then Junior will have to take double care. He will have cp and vario :!
perfect, like to drive my Ciao A with rigid fork then 😀
hej, is there a special requirement for the engine type such as elo-ignition? Or is it also possible to drive with a contact ignition engine?
ooooh, just see this nice tour. I would like to join you guys if possible.:D
Piet30 reageerde in het onderwerp FonS – Ultra Chrome Special in het forum Projecten 14 jaar, 11 maanden geleden
after having seen the Ultra Chrome Special life on the Limbo I need to say, great work. I like it. :thumb
Piet30 reageerde in het onderwerp Sprocatti in het forum Pub talk 14 jaar, 11 maanden geleden
Filippo: I bought two carter sets, one for me and one for another guy. This reduced shipping cost. 😉
Mistered11: ignition from a standard Ciao engine does not fit to the Sproc carter as it is now. The carters are prepared for inner rotor ignition only.
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 11 maanden geleden
Thanks for the positive reactions. :thumb
short update on the paint work.
About 10 days ago I coated the frame with “roestige kleur”
after the first day the paint started rust
and now after some days holiday it is more rusty
wuha, maybe it is to hard for me. Will stay with the old fashion one. 😀
Hope this engine will run like expected. Painting of the frame will be finished end of April and then I can try the first test run.
so, engine fits into frame now.
now paint work is ongoing. 😀
Piet30 reageerde in het onderwerp Sprocatti in het forum Pub talk 14 jaar, 12 maanden geleden
hehehe, it’s hand made. 😉
The bore is 57mm and it is round. I’ve marked the bore with blue color. The rest are ports.
Yes, it’s ordered direct from Sprocatti. Waiting time is since end of Jan/11.
That is the link:
http://www.sprocatti-motori.com/Carter_lamellare.htmRegarding cylinder I’m not sure so far. Need some inspiriations. Also about the ignition, should be a inner rotor ignition.
Any suggestions or experiences from your side are welcome.:D
exactly, I like to use it with Kick drive. 😀
Piet30 reageerde in het onderwerp Junior Piet's Simo side inlet in het forum Projecten 15 jaar geleden
update.
Yesterday we had the first short run of the engine and today we found that :boos
fixing a new gasket was not enough, too much compression. Then we put two head gaskets in and the engine runs nice 😀
Piet30 reageerde in het onderwerp Carnavalsmeeting Thorn 2011 (13 Maart) in het forum Overige meetings & evenementen 15 jaar geleden
yes, very nice meeting.
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 15 jaar geleden
yes, that’s power man 😀
The color will change at the end when everything is finished as I still need to drill some holes, expand the back fender for a bigger tire and also want to weld some reinforcements to the frame.
And serious thinking if I should change the seat. :lol
so, some progress here 😀
2 1/4 x 17″ still has space to the frame. Maybe 2 1/2 x 17″ will fit
The engine completed now. 😀
turns perfect 😉
Piet30 reageerde in het onderwerp Speedbuxy projecten page in het forum Projecten 15 jaar, 2 maanden geleden
Andree, I have seen the same symptoms on an Athena cylinder. Due to bigger mass around cylinder pin holes the expansion at heat in this areas is bigger then at the rest of the cylinder. The particles you found can be a result from that piston pressing in that areas.
I know some people who opened the cylinder pin channels like on the pic here to…[Lees meer]
ohoh, only 200 km ? Intersting that the marks are more or less in the area where the two cylinder pins are.
May be heat problem, what cylinder head did you drive?
:: Piet30
