Piet30 reageerde in het onderwerp VCM2011 foto topic in het forum Vespa-Ciao.nl 14 jaar, 8 maanden geleden
here my pics
Piet30 reageerde in het onderwerp Rickieboy zijn Xsh Simonini Retro ciao in het forum Projecten 14 jaar, 8 maanden geleden
wow, very nice. =)
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 8 maanden geleden
Mike, :thumb
Edjuh, yes I think so, will have the same function like harder clutch springs I think. The devil sticks in the detail 😀
so, some news.
Adapted engine with Simo clutch, 83mm pully, 8,5er gearbox.
Interesting thing is that the Simo clutch bell has an inner diameter of 84,7mm, as a standard clutch bell has only 82,4mm. 😀
Piet30 reageerde in het onderwerp Speedbuxy projecten page in het forum Projecten 14 jaar, 8 maanden geleden
:duivel
:swinging
51mm bore
checked the fork spring system and the plastic bushes were oval.
Changed the plastic bushes and inner tube with brass bushes and 12mm piston pins. 😀
and ready to go
as it is not easy to fix the saddle spring on a C24 frame I compressed the spring upfront. 😉
and schwups, easy to assemble
enough for today
Turbociao, yes that can be 😀
Do you have an idea about the color code of the rims? I like to repaint some scratches by hand. -
so started with assembly
red Malossi fork springs :haha
what do you think about that color combi?
yes, why not. Send me a pm for further actions 😉
I don’t know 😕
It is leaking, but has papers.
yes, and here the flower for the bee 😀
new frame, new luck 😀
Piet30 reageerde in het onderwerp VCM 2011 met overnachting: Scoutinggebouw! in het forum Vespa-Ciao.nl 14 jaar, 8 maanden geleden
Junior and Piet30
Piet30 reageerde in het onderwerp Piet's Italian Brommer Project in het forum Projecten 14 jaar, 8 maanden geleden
Spulleke, has still can order the 46mm black Pinascos. 😀
Jarco, yes this are Carrera Universal toys for relaxing in winter time. 😉
The bearing collection is still growing 😀 A good tire sometimes is usefull, you never know.
wuhaha, I hope not. 😀
hehehe Spulleke, in addition to that project I have to finish my VCT11 project and my 2 gear Grillo project.
So then, put the flywheel on my milling machine and milled 4mm off. This is exact the right thicknes to fix it into the frame. :thumb
also received a new front lamp
Piet30 reageerde in het onderwerp VC Meeting 2011 in het forum Vespa-Ciao.nl 14 jaar, 8 maanden geleden
Junior and I like to come also if nothing comes between.
We will need a overnight too. 😉
Piet30 reageerde in het onderwerp Zomermeeting Thorn 2011 (17 Juli) in het forum Vespa-Ciao.nl 14 jaar, 8 maanden geleden
nice meeting, but very less number of people for a summer meeting. 😕
But nice to meet the hard tour core again. Good that Jordy’s hand was working fine for mäp mäp mäp …..Missed that deafening loud sound of his Simo.:D
Stephan, mooi to see that your Tiff is in best form after the Oldi tour again. :thumb
Jarco thanks, this will be an easy job for my milling machine. :thumb
:: Piet30
