Piet30 reageerde in het onderwerp Waarom? in het forum Projecten 14 jaar, 6 maanden geleden
perfect and clean work with the deserving result. :thumb
I’m missing the pink Citta front mask :lol
Piet30 reageerde in het onderwerp VespaAvanti's Vespa's in het forum Projecten 14 jaar, 6 maanden geleden
cool, the stable low rev “Standgas” is perfect :thumb
I never got that on my engines.
wow, fast work man. 😀
like to see the video :thumb
aahh, new Grillo Engine? =)
Or for the Tiffy :rules
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 6 maanden geleden
are you sure? The rev counter is a little longer than a speed counter.
Maybe I can check that option. 😉
Daan, you can get this stickers from EditionMike, our paint master 😀
Different words are possible.
see his link
mmmh, yes looks a bit different. But that is the headlight where I fixed the RPM counter in.
Maybe I will paint the housing black.
update, mechanical work finished. Now my favorite electric work can start :'(
beunhaaz, ok.
Hans, 10,5 ratio is far to short, too much wheely risk, don’t like that. If the 9:1 ratio improve the character more drivable I will keep it with vario.
If not I will drive mono. -
update 😀
colored the back lamp glas dark
and the last try with Malossi 9:1 before I change back to Mono again.
Piet30 reageerde in het onderwerp How to grind Nikasil in het forum General questions 14 jaar, 7 maanden geleden
yes, I think so, high speed and low pressure on the grinder.
But are you using soft or hard grinders? Or small millers?
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 7 maanden geleden
was busy again with the cables and grips, with brake light switches 😀
looks modern style now
Piet30 reageerde in het onderwerp Waarom? in het forum Projecten 14 jaar, 7 maanden geleden
ui, that looks promising. :thumb
Like to see the test run. 😀
oh, what is an ivano bell?
Edit Jarco: The famous Ivano Bell 😀
hahaha, the clutch bell is the rest from my former rost look. 😀
But I think I need a larger ratio on gearing too. At the moment it is 10,5:1.
video with a little more than half gas with my test driver.
He had to be careful with the throttle and to put the body weight in front to keep the front wheel down. 😀
[youtube=nqd49r-o8FE]
new style with black 5 spakers and Vario.
And a rev test for Hans after about 20 to 25 sec idle gas 😀
[youtube=jpgd0g-3RA4]
today I got the Malossi air filter 😀
But it is with black filter foam, a red foam is ordered now.
But even with the black filter foam it runs great on Mono. Much better than with the Polini filter.
Some people are forcing me to use vario with that engine, so I will try vario also for comparison.
Here a sound check with Malossi filter…[Lees meer]
Martino, yesterday I tried the Simo Thunder in combination with the 19mm PHBG carb., Polini airfilter and it was frustrating.
No rpm’s and no speed. :boos
Today I put the calli on and removed the Polini airfilter. The different was like day and night, black and white. 😀
But without airfilter it get too much air now I think. Does somebody…[Lees meer]
Piet30 reageerde in het onderwerp Glenn's Boxer 1 oldtimer. in het forum Projecten 14 jaar, 8 maanden geleden
very nice Oldtimer :thumb
:: Piet30
