Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 3 maanden geleden
now I got a Mix head lamp and fixed a LED lamp with 60 single LED’s into it.
connected to a 12 V Akku what will find place under the right side cover later.
Piet30 reageerde in het onderwerp Piet's Italian Brommer Project in het forum Projecten 14 jaar, 3 maanden geleden
Lastpak, thanks I know what you mean :thumb
Everything ready to run now, but without water cooling system as I’m missing this stupid 1/2″ cooling line fittings.
so tried a short start without cooling. It feels that the water pump pulls some power from the engine. :lol
[youtube=2komkEI_kIY]
[youtube=tnEk3H9kkKQ]
Vertigo, that is a great idea. :thumb
turned the shell and nice is
thanks, 41mm LC on EVO carters must run like hell 😀
As JMPB had a special price for the Gianelli Fire I bought on. It looks nicer than the Leo exhaust. 🙂
but like Vertigo said, it fits not very good at the rear fixing point. I think I will make an additional bracket to get it right.
cylinder fixing may work, but I will not…[Lees meer]
Piet30 reageerde in het onderwerp Gianelli Fire ? in het forum General questions 14 jaar, 3 maanden geleden
Hi Martino, that helps a lot :thumb
I think that I will order one, JMPB has a special price at the moment. 🙂
Piet30 reageerde in het onderwerp what link to see youtube in het forum General questions 14 jaar, 4 maanden geleden
thanks man :thumb
can be closed here.
Piet30 reageerde in het onderwerp Junior Piet's legal 50km/h Ciao in het forum Projecten 14 jaar, 4 maanden geleden
Stephan, yes we can drive reso exhausts on Sunday at lunch time and nobody is saying something against it. 😀
Junior already fixed the cooling cap and assembled 5,7 gr vario weights. Then made some more nice trials (as I said, at around lunch time) 😀
Tomorrow he will try a 88er jet.tneural, yes, I use that BelRay since I was 16 years old…[Lees meer]
jep, cooling cap will come before next drive. :thumb
hahaha, evil Haloween engine 😀
My Junior fixed the engine and filled the tank with 1:40 mixture.
after 2 meter pushing the engine made it’s first noise. :thumb
[youtube=7uq6uD62MBc]
a litle adjustment on the Standgas screw
[youtube=BmPLpuAR80Y]
and then the first some 100 meter tour
[youtube=z-ms2wtGrp8]
My son now…[Lees meer]
mmmh, so something between 50km and 500km.
I only use BelRay Si-7 full synthetic oil with 1:40 mixture. Hope this will do the job for 100km slow drive:D
yes, I have an idea how to handle with the rev’s.
I only was not sure about the distance. (300, 400, or 500 km) as I didn’t have a new Aluminium cylinder before. Maybe it is different to cast iron cylinder.So 500km is something what I can tell to my Junior. :thumb
Piet30 reageerde in het onderwerp Junior Piet's legal 50km/h Ciao in het forum Projecten 14 jaar, 5 maanden geleden
yesterday Junior finished the engine. :duivel
How many km would you recommend to drive slow with that new cycilnder?
Piet30 reageerde in het onderwerp Piet's VCT11 Simolini Project in het forum Projecten 14 jaar, 5 maanden geleden
yesterday my son and I made some fine adjustments on the carb. Changed from 50 to 45er secondary jet.
Also we found out that with full gas on the handle bar the carb was not opened 100%. So we adjusted the gas cable length also to full opening of carb with full gas on handle bar.And now it runs very nice for my understanding.
The only…[Lees meer]
Piet30 reageerde in het onderwerp Tonni's CandyRed Ciao in het forum Projecten 14 jaar, 5 maanden geleden
OMG:S
You better should go for contact ignition with a standard light Piaggio flywheel.
Piet30 reageerde in het onderwerp Piet's Italian Brommer Project in het forum Projecten 14 jaar, 5 maanden geleden
just bought a Leo Handmade from Sander, thanks again.:thumb
And fixed, hope this will give some power :lol
Piet30 reageerde in het onderwerp Herr FlicK's Special (Schijfrem, kickstart reedvalve & foxvario) in het forum Projecten 14 jaar, 5 maanden geleden
ohoh, be careful with your shoe lace and front vario =)
Piet30 reageerde in het onderwerp Yannick's 70cc LC Evo Ciao in het forum Projecten 14 jaar, 5 maanden geleden
beun_ciao :
mooi dat je de pakkingen hebt, maar hoe ben je daar aan gekomen?that you can have easy.;)
check link
hahaha, in the wind shadow from you maybe 58 km/h 😀
yes, and the positive is, Junior’s weight is about 45 kg, so good chance for his speed goal.:D
Andree, this is an Italien Ciao Moped with original color. I have never seen that before.
Piet30 reageerde in het onderwerp Sprocatti Citta in het forum Projecten 14 jaar, 6 maanden geleden
ah progress. :thumb
:: Piet30
