Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 10 maanden geleden
Hi Edjuh, yes the frame need to get some modifications, not only for the engine, also to make it stronger at the rear end I think.
For that I try to weld some stiffness sheets in.
I bought the frame like it is in the moment, otherwise I would have made the modifications before painting. But I think it is not a big problem to paint the modified…[Lees meer] -
misterd11, it is interesting that the modifications on the frame aren’t different to the changes to mount a new model Simo.
Is there somebody here in the forum who already did that modification for the new Simo in a Ciao frame?
The kart pump is similar to the Polini pump.
Something like that…[Lees meer]
yes, that is right. The right front side below the fuel cran need to be modified.
Regarding water cooling I need to make some thoughts, may be a mechanical driven pump from Kart race engines.
It is a Parmakit cylinder.
Here some pics when I tried to put the block into a frame
Piet30 reageerde in het onderwerp Florian's Projecten in het forum Projecten 12 jaar, 10 maanden geleden
Nice, I hope the controletties in the Harz will be at home at that time :bier
thanks man. 😉
But now I’m facing another challange. I will have to make a big hole into the frame to make space for the ignition.
and in combi to green, a orange cylinder 😀
hahaha, yes JMPB is very fast. 😀
Yes the first thing that I saw was that the ignition coil is black and not pink. 😕
I mean the 2mm podest in the middle of the carter where the sealing ring comes in.
I had to enlarge the pocket in the rotor for that, otherwise it came not deep enough on the cone.
ignition received 😀
krukas and rotor cone polished together
enlarged the pocket in the rotor to fit with the carter
fit perfect
Piet30 reageerde in het onderwerp Question to HPI inner rotor ignition in het forum General questions 12 jaar, 11 maanden geleden
ah,ok, understood. 😀
Piet30 reageerde in het onderwerp What inner rotor fits? in het forum General questions 12 jaar, 11 maanden geleden
Hi Martino, thanks for the info.
I knew that Sil is using a HPI ignition, and I checked the HPI web side, but there are no prices on the HPI side.
So I thought that they are no delivering to single persons, only to dealers.Nice to see that JMPB is selleing that ignitions, even because I checked the JMPB side yesterday, but didn’t see it. :thumb
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 11 maanden geleden
Arvid, yes looks very cool. :relax
as there was not enough sealing surface against the cylinder port in the small carter half I tried to fill that area up with Alu-soldier.
wil see the outcome after cooling down and grinding. 😀
EDIT:
finished, looks very good.
Piet30 reageerde in het onderwerp Sluis tot strand tour 2013 in het forum Vespa-Ciao.nl 12 jaar, 11 maanden geleden
that was a very nice tour:thumb
Well organized, special thanks for the lecker soup 😀
My Junior and I had a lot of fun, it was real good thing to meet with you all again.
But what was happen with the two guys who where catched by the Police? Didn’t get that all due to my bad Dutch. :lolsome pics from my side
I have rent a trailer to transport our Mopeds. No way back from now, see you tomorrow. 😀
Piet30 reageerde in het onderwerp Waarom? in het forum Projecten 12 jaar, 11 maanden geleden
ui, that looks very clean 🙂
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 12 jaar, 11 maanden geleden
wow Frankrijk, that is cool.
For how long will you be there?
hi DR-flenny, any rough idea about the weather forecast for sunday? 😀
Piet30 heeft het onderwerp Piet's Sprocatti EVOLUZIONE aangemaakt in het forum Projecten 12 jaar, 12 maanden geleden
Hi there,
when I saw the new Sprocatti carter development called EVOLUZIONE I couldn’t say no. 😀
I got a nice package from Italy with the EVO carter set for superior lamellar.
Also the 46mm stroke krukas with 14mm piston pin. Together with the 50mm Parmakit cylinder set.
I’m looking now for a nice ignition. Thought about a Selettra ignition,…[Lees meer]
Piet30 reageerde in het onderwerp Jordy.s toer ciao in het forum Projecten 13 jaar geleden
hey Jordy, cool that you are back. :thumb
Nice Ciao, hope we will meet again sometime on a tour.
Piet30 reageerde in het onderwerp Parmakit 50mm in het forum General questions 13 jaar, 1 maand geleden
ah, good info. Maybe I should buy that 50mm cilinder from Sprocatti.Then it should fit.
mmmh, there is no picture on the Sprocatti side.
I found this on Ciao cross club
Piet30 reageerde in het onderwerp Is that a Zirri ? in het forum General questions 13 jaar, 2 maanden geleden
ok, thanks.
You are right, looks that the Fabrizi SX was playing a big role in the past.
If I think about a Fabrizi exhaust I only have this one in my mind. 😀
:: Piet30
