Piet30 reageerde in het onderwerp Wilk1985 perso in het forum Collecties 12 jaar, 3 maanden geleden
excellent work done on the vario gear box :thumb
Maybe the CNC Alu triangle for the wheel bearing would be the I point to your great work.
Like to see the bearings in your fridge between the bread 😀
That is how it works, did you need much force to press the bearings in? How did you press them in? -
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 3 maanden geleden
ah, ok. If the engine is loosing power higher than 90°C I’m soothed. I only don’t want to damage the cylinder with the first try.;)
Maybe my thermo sensor is not the best as I made it by myself. I used a screw, drilled a hole through it and glued a sensor in it.
During engine run it showed ERROR, when I stopped the engine it showed the…[Lees meer] -
oki, I will change to vario for next try. 😀
nejc93, thanks, maybe 144 main jet is a good starting point. Honestly, I do not know what jet is in the carb, just plug and play for the try run. :lol
What vario are you using on your race Bravo? Is it standard clutch or Fox clutch?
today I tried to start with pulley drive, but without decompression I had no chance. So starting again with drilling machine.
The thermo sensor only worked when the engine was switched off. Need to have a better one for the future. But water temp of about 79°C was not bad I think.
also the small fuel tank was leaking, nice smoke when…[Lees meer]
Andree, open for any proposal 😀
@ktmgek, I like to run it sometimes with race fuel (maybe for races)
https://ssl.dein-isp.net/rennbenzin.de/index.php?index=1&lng=de&menuid=6&ordner=shop.artikel-17-214
this can not be mixed with standard fuel. And as the race fuel is expensive I will have it under control with the small race tank.
The…[Lees meer] -
update about cooling installation.
Piet30 reageerde in het onderwerp Piet30 E-Start Tiffany in het forum Projecten 12 jaar, 4 maanden geleden
Thanks a lot, so far the Tiff is wayting for next spring or sommer.
I will leave it in original condition and plan to ride some tours and to meetings with it.I’m sure that this will be a eye catcher as most of German people are not knowing that something like this was build.:D
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 4 maanden geleden
Hi ritze, thanks for the info :thumb
So the akku will last longer than the fuel in my race tank. :hahavespaAvanti, it looks that this pump is used in many Mercedes models, a copy from the web
für Mercedes Benz W202 W124 W210 W461 W463 Sprinter Vito Vaneo V-Klasse usw.
bitte vergleichen Sie die Pumpen!
thanks, yes, it keeps me busy 😀
ritze, yes, it is a Mercedes W210 pump. You have good eyes 😉
With what akku are you running your pump and how long is the akku working from full charge to empty?
I have a 2,2 AH akku, but do not know what the pump is pulling. -
thanks :thumb
I changed the stuur from Cross style to more racing style 😀
also found a place for the coolwater pump
haha, after I got a complete disc brake set incl. orange 5 spoke wheels my color combi is very similar to that in the video.:D
next step will be a secondary coolwater pump from a Mercedes and a scooter radiator.
Piet30 reageerde in het onderwerp Edjuh's perso in het forum Projecten 12 jaar, 4 maanden geleden
Nice, you know where it is relaxing 😀
Piet30 reageerde in het onderwerp Piet's Off Road Bravo in het forum Projecten 12 jaar, 4 maanden geleden
didn’t find Enduro tires from Pirelli but from Heidenau, VeeRubber or…[Lees meer]
Piet30 reageerde in het onderwerp Piet's Off Road Bravo in het forum Projecten 12 jaar, 5 maanden geleden
haha, yes the topic is old but still ongoing. 😀
Can’t remember where I got the tires from, need to check that if you are interested.
In the meantime I have put a Malossi RV block with a 50cc Athena cylinder in.
Here was the first drive test.
[youtube=kJmONbRuDRo]
Piet30 reageerde in het onderwerp Zuigerstop, yes or no? in het forum General questions 12 jaar, 5 maanden geleden
that’s why I’m asking 😀
Using in combination with inner rotor.
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 5 maanden geleden
haha, yes, that is very sexy, I only was sitting next to it with a coffee for relaxing. :lol
I like the rear frame fixing, it fits perfect to the Ciao frame and is damped with two rubber washers.
I hope that I will get answer from Roost regarding a sprint silencer 😀
thanks for the comments.:thumb
Lennaert, maybe I will fix some 17″ wheels 😀
Lastpak, yes it’s a Roost 😉
For the next try I need to fix the cooling system, then I may can have the first roll out. 😀 -
thanks, for the first trial I’m happy so far 😀
Now I got the right exhaust for it
Edjuh, now we are at the peak. 😀
First short start without cooling water
[youtube=wCyWAyMnmHE]
Then filled water into the cylinder and had a longer try with very little throttle movement.
[youtube=iqZ5G3eWOXU]
Andree, comming closer and closer. 😀
At my first starting trial one or two weeks ago the rotor was sticking to the carter when I used the drilling machine for starting.
Here some scratching marks inside the rotor. The result of this, no movement of the krukas anymore.:((
After turning the rotor inside a little deeper I had another…[Lees meer]
:: Piet30
