Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 1 maand geleden
Thomas, the place is maybe not as nice as Thailand. 😀
luuky1997, if I remember right I got this seat from Switzerland. It is a Polini race seat I think.
the HPI work great, one or two krukas turns and it starts 😀
But I forgot to put the shoke out during driving, I think that is the reason why it runs with too much fuel.
I have ordered a standard 17mm drive belt, will see how this will work. But the great thing is that the Stage6 clutch work also pretty well. Even as it turns in wrong direction. 😀
today first drive test. Still with 13mm drive belt but 130 main jet.
[youtube=3iC9AKnKSW0&feature]
yellowcitta, yes, they end at 13mm and then start again at 17mm. Nothing between 13mm and 17mm. 😕
TJOEP, thanks, Optibelt look like an option, will check that.
Arvid, thanks for the instructions, will try comming weekend if there is no rain. :thumb
ktmgek, lightlord, yes, I’m also anxious to know if this thing will actually drive :lol
But now I have a little problem to get the right drive belt.
I have checked many many shops for a drive belt with width between 14 and 16mm and a length of about…[Lees meer] -
short update
longer fox axle received and fixed.
now the drive belt runs inline from clutch to variator
as now the 13mm width drive belt is sitting too deep between the complete closed discs. Tomorrow will order a 15mm width drive belt.
after that, all is ready now for the next drive trial. Hope that the clutch will open…[Lees meer]
Piet30 reageerde in het onderwerp Piet's Simonini 4p in het forum Projecten 12 jaar, 1 maand geleden
DR-flenny forced me to put it under a Grillo :whistle
For that I have two options
Piet30 reageerde in het onderwerp Tonni's Vespa Boxer 1 in het forum Projecten 12 jaar, 2 maanden geleden
Tonni, welcome in the old men class 😀
Piet30 reageerde in het onderwerp Drive belt width Fox clutch in het forum General questions 12 jaar, 2 maanden geleden
it has nothing to do with the belt width but maybe is interesting. I bought a Malossi variator for Minarelli engine. Outer diameter of the vario is 97mm.
I used a back disc from Motoforce and milled the cooling ribs away.
Then milled the anti turn safety profile from a Ciao Malossi Multivar bush into the Motoforce…[Lees meer]
Piet30 reageerde in het onderwerp VCT 2014 —> 7&8 juni in het forum Vespa-Ciao.nl 12 jaar, 3 maanden geleden
JuniorPiet and myself would like to join if it is not too late yet.
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 3 maanden geleden
SpeedyVespa, still need to adjust the carb. for the first drive.
TJOEP, yes, there is space. in the cover for maybe two additional ball bearings.
Already got gaskets, two original size needle bearings for cover and box and the two additional ball bearings. 😉
short update with scooter vario
Piet30 reageerde in het onderwerp Fredzzz 2.0 in het forum Projecten 12 jaar, 3 maanden geleden
Nice engine. :thumb
If you have the chance, try a Yasuni or Roost exhaust. 😉
Piet30 reageerde in het onderwerp Red Malossi pressure spring in het forum General questions 12 jaar, 3 maanden geleden
Oki, I thought so.
I will tell him to order the yellow one :bier -
Thanks 😉
I’m asking for my JuiorPiet, his setup is a Polini EVO, 46mm Pinasco black, 19mm carb and Calibrata.
Would it be an advantage to use the red spring, or would a yellow spring be more comfortable in daily use? -
Hi Jelle, I have heard from two different people that Toyota parts could be used, but I do not know any details. 😕
I bought my Fox/Vespa axle here on the forum. Hope this axle will work for a while.
Just upfront I’m planning to fix a new needle bearing and one or two additional 4mm ball bearings for more reinforcement into the gear box lid. -
hey man, how is it going in Thailand? :bier
I thought so in general, all Scooter clutches are turning worng direction. But funniewise the Fox clutch is working in both directions.
What springs were you using on the Stage6 clutch? Maybe they were too hard? I will try the softes once then.
ok, thanks.:thumb
during waiting for the main jets to adjust the carb I received the Stage6 clutch.
That is an fantastic thing, total easy to change and adjust the springs without disassembling the clutch.
Also there are additional small weights to finetune the weight of the clutch lining arms. :thumb
Piet30 reageerde in het onderwerp Wilk1985 perso in het forum Collecties 12 jaar, 3 maanden geleden
ah, ok. So it still need some force to press even if you cool down the bearings and warm up the housing.
I thought that the temperature difference could be helpful for the assembly.I did it with a small 6 ton press and used some screw nuts what fit to the bearing diameters.
Piet30 reageerde in het onderwerp Zuigerstop, yes or no? in het forum General questions 12 jaar, 3 maanden geleden
short response.
I bought an zuigerstop and used it to fix my clutch on the Sprocatti engine. –> Perfect thing. :thumb
:: Piet30
