Piet30 reageerde in het onderwerp Piet30 3-Gear Bravo in het forum Projecten 11 jaar, 11 maanden geleden
Cool, is that a yellow wheel?
So far I only saw white and red wheels. -
this Italien Moped builders. 😀
They are building a hand full of 3-speed gearboxes, and this in addition with ratio variants.
So it looks that yours is a little longer then the one I’ve build.
How is it drivable with a standard engine, or are you runing it with a tuned engine? -
yes, it has neutral between 1st and 2nd gear.
What ratio does your 3-speed gearbox have in the 3 gears?
Mine is about:
>1st- 14,5:1
>2nd- 10:1
>3rd- 7,5:1 -
I will use this tooth wheel tree on the right side (left side is 2-gear tooth wheel tree)
in combination with that tooth wheel
[youtube=yggBnvR8XqA]
Piet30 reageerde in het onderwerp VCT 2014 —> 7&8 juni in het forum Vespa-Ciao.nl 11 jaar, 12 maanden geleden
His name is Seru.Ch
Jelle,
just got the info from Doktor Motor that he can not join the tour due to some private things that he has to do at that time.
But one other guy from our PMT Forum (Seru.Ch) would like to take over his place and drive the tour for him if this is ok. -
Piet30 reageerde in het onderwerp INT: CNC clutch bells for variomatic in het forum Onderdelen aangeboden 12 jaar geleden
yes, that is why I’m asking. Normally the discount and delivery cost should be cleared upfront before starting an interest review.
Is there a discount, did you check that before starting that int?
Gab_pei has low shipping cost anyway, why shipping it first to Germany and then to NL?
Piet30 reageerde in het onderwerp Different rear variator clutches? in het forum General questions 12 jaar geleden
there are about 3 different vario clutches on the market.
Here is a pic with the clutches and the relevant springs
The Malossi springs only fit in the left clutch
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar geleden
short update with 50er secondary jet. 😀
Tomorrow will try an 48er jet
[youtube=lLfaUX7ByaE]
Piet30 reageerde in het onderwerp Jarco's Superbravo 2 ( replica ) in het forum Projecten 12 jaar, 1 maand geleden
Jarco, how did you block the clutch for disassembly the 19mm nut on the gear axle?
Piet30 reageerde in het onderwerp Lennaert zijn rommelpagina in het forum Projecten 12 jaar, 1 maand geleden
maybe you can make an adapter plate what you screw on your inlet half and what has holes for a wider membran housing on the oposite side.
That is the plan how I like to do it with my Simo 4p and a Stage6 membran housing.
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 12 jaar, 1 maand geleden
niek, yes that is right :thumb
I made some pictures in that link:
http://www.vespa-ciao.nl/forums.php?m=posts&q=33605
sx3-swe, yes there were some modification on the middle tube what is in the frame.
the fork is from a TZR50 😉
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 12 jaar, 1 maand geleden
petrol groen or aqua blauw :thumb
Piet30 reageerde in het onderwerp ktmgek's vespa ciao snor projekt in het forum Projecten 12 jaar, 1 maand geleden
Very nice project. :thumb
I like your possibilities of machining parts, special the turning machine. 😉
Cool, that looks professional. :thumb
Piet30 reageerde in het onderwerp Sluis tot strand tour 2014 in het forum Vespa-Ciao.nl 12 jaar, 1 maand geleden
that always was a very nice tour, so my Junior and myself would like to join you if this is ok.
sorry, no I havn’t a drawing. I bought the frame here from somebody on the forum and he welded some square tubes to the frame to fix the seat.
Today I received a 17mm width drive belt. Standard width, cheap. 😀
:: Piet30
