Piet30 reageerde in het onderwerp TK: Simonini 42mm LC kit & 2x 41mm DR in het forum Onderdelen aangeboden 11 jaar, 4 maanden geleden
200,- ex for the Simo kit
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 11 jaar, 4 maanden geleden
as said, there is not much space for an airfilter, so I build one by my own using a Malossi filter housing with a custom cutted expanded metal and red Malossi filter foam.
And now the carb setup starts at zero. Lightlord, due to that I can’t say how fast it is.
So far Junior and I reduced the secondary jet from 48 to 42. But…[Lees meer] -
Piet30 reageerde in het onderwerp De Oldtimer Tour zondag 23-8-2015 in het forum Vespa-Ciao.nl 11 jaar, 5 maanden geleden
me too 😀
Piet30 reageerde in het onderwerp Gasket for 2-gear gearbox in het forum General questions 11 jaar, 5 maanden geleden
🙂 was a rough estimation. I measured the thickness of the old gasket, it is 0,3mm.
Laser cutted gasket sound great. :thumb
Jasper, yes that could work. But when I opened the gear box the old gasket was sometimes glueing on the housing and sometimes on the cover. So the old gasket is splitted in some areas and cracked many times. No chance…[Lees meer]
mmh, then I do not have the thickness of a paper gasket (maybe 1mm) between housing and cover.
The cover then could be too tight on the housing and squeeze the gear wheels in the bearings. -
yes, that is finally what I need to do.
Can you recommend a gasket paper with good function for gearbox oil?
hey, cool, but it shows 25,- delivery cost :((
Piet30 reageerde in het onderwerp Piet's Sprocatti EVOLUZIONE in het forum Projecten 11 jaar, 5 maanden geleden
Crullie, Junior is my test driver. he told me that this engine is pushing like a steam train, not ending giving more and more pressure.
He also told me to use an air filter, but there is not much space for an air filter in the frame. Need to make some investigations to find something what fit.
Andree, the sound goes through the bones. When…[Lees meer]
new update with 4,5gr vario rollers 😀
[youtube=dRRnUMMBRdY]
coolwater temp. is also ok
Piet30 reageerde in het onderwerp VCT 2015 in het forum Vespa-Ciao.nl 11 jaar, 5 maanden geleden
count Junior and me ma in.
Piet30 reageerde in het onderwerp Quality of DMP krukas? in het forum General questions 11 jaar, 5 maanden geleden
oh damnd, that is bad 😮
oke, thanks for the infos. Will go for a good used original Piaggio one. :thumb
Piet30 reageerde in het onderwerp Ciao1968 Perso 😉 update 07-07-2015 in het forum Projecten 11 jaar, 6 maanden geleden
wow, cool :thumb
Piet30 reageerde in het onderwerp Jelle's collectie in het forum Collecties 11 jaar, 6 maanden geleden
cool, how did you fix the big fuel tank from the two gear Bravo?
Piet30 reageerde in het onderwerp Lightlord's Dizzy/Gypsi in het forum Projecten 11 jaar, 6 maanden geleden
looking nice, I like the position of the CDI :thumb
Good inspiration for my Junior’s tour Citta build. What length of shock breakers did you use?
Piet30 reageerde in het onderwerp Piet's Simonini 4p in het forum Projecten 11 jaar, 6 maanden geleden
ah, understand. As I like to coat my stuur also in Candy Blue I can do that together with the subframe.
In the meantime I fixed the back wheel
This is kick ass blue 😀
As I could not find a single outlet flange from Simonini I got two custome made once. One with outer diameter of 34mm for my Roost and one with 30mm outer…[Lees meer]
@ Crullie, I think there is no special color number for the Candy Blue. I told the coater: Candy Blue, and it looks like the pictures on this web side.
http://www.deteil.net/V4/LS_Spezialeffekte.html
@ Lightlord: you mean coating the subframe also Neon Yellow?
@ Wilk, I saw the candy blue spoke wheels on above web side. So I had a good…[Lees meer]
Avanti, I was waiting for you since 5 years. But now I have to move 😀
Over my vacation the frame parts and wheels were powder coated. Wheels in Candy blue and frame in Neon yellow :lol
Piet30 reageerde in het onderwerp De Oldtimertour zondag 7 september 2014 in het forum Vespa-Ciao.nl 11 jaar, 6 maanden geleden
Nice pictures and filmpje, look like a super Oldtimer tour. =)
Piet30 reageerde in het onderwerp TK: Sprocatti engine in het forum Onderdelen aangeboden 11 jaar, 6 maanden geleden
do you know what cilinder that is?
:: Piet30
