Oliver Skauenborg reageerde in het onderwerp Pinasco flywheel for CDI? in het forum General questions 7 jaar, 8 maanden geleden
Okay. Is there any way i can shave some weight off the original or can i use a flywheel that is meant for Points ignition?
Oliver Skauenborg heeft het onderwerp Pinasco flywheel for CDI? aangemaakt in het forum General questions 7 jaar, 8 maanden geleden
Hi guys, does anyone know where you can buy a lightened Pinasco Flywheel for CDI ignition?
I have been looking at the Malossi ignition… But it is pretty expensive, is it worth it?
Its because i have a project with Speed engine CDI crankcase and i want quick throttle response for example wheelies, but the original flywheel is very heavy
Oliver Skauenborg is geregistreerd lid geworden 7 jaar, 8 maanden geleden
:: Oliver Skauenborg
