Italjohn reageerde in het onderwerp Piet30 Oldtimer resto in het forum Projecten 10 jaar, 7 maanden geleden
Excellent work there mate :thumb
Italjohn reageerde in het onderwerp Italjohns Bravo 1984 (English) in het forum Projecten 10 jaar, 7 maanden geleden
Anyone know which stand will fit my Bravo?
Ciao
Citta
By the way, here are a few pics of my messy workshop :thumb
Aha……. that expalins it 😀
In my manual it says “voltage regulator for indicators”. I guess the third coil is for extra wattage, so it can power a battery and indicators?
I have got some problems again.
1.I can’t figure out how to install the capacitor????
Anyone who have a Polini Speed engine and have some pictures of how to do it?
There are no hole to install the capacitor in the Speed engine???
My engine has 3 coils, not 2 as I have seen on Google pictures.
2.The felt “greaser” pad won’t fit any…[Lees meer]
Found a pic online for the decomp valve.
Now I know how to install it 😀
But if someone have pictures I would love to see them :thumb
Got one problem again.
The decomp spring don’t fit like I was hoping for.
I also miss this part.
Can someone post a picture that shows how to install it?
It took unbeliably long from Nederland to Norway.
6 whole days??
21.08.15 Today the parts are finaly in my house.
Engine building tonight 😀 -
Good tip.
I will look into that :thumb
I was planning to use a piece of old brass bearing, and cut two piecses of that. -
Thanks again guys.
Just found this pic online.
It’s a Bravo with long fin (Ciao) head 🙂 -
Difference is the cooling fans but doesnt matter mucht for your bravo take the one on the left with side fans.
Ok, but I have bougth the Polini cylinder with the long fins, will this fit without any probelems?
What about this “slack” between the piston and bearing?
Is there any “shims” that make the bearing stay in the center of the crank?
Can someone tell me what is the differece between these two heads?
My Bravo original engine has the small one to the left.
My Polini engine has the one to the right.
Will this still fit in the Bravo?
Aha 😀
That clear things up, thanks 🙂
Maybe my Bravo have this clip already??
We will have to wait and see when I have taken the engine out of the frame.
More questions.
The screw treads you see in this picture is missing from my Polini cylinder.
How do you fasten the top cover without this screw?
Italjohn reageerde in het onderwerp SI wheels in het forum General questions 10 jaar, 7 maanden geleden
Now I see the differece.
Thanks for the info 🙂SI wheel
Bravo wheel
Ok, can I just switch my Bravo brake over to this wheel?
And will my Bravo gear box fit the rear wheel without any modifications? -
Manage to install the bearings and crank tonight 😀
I’m very happy with the job, as the crank spinns freely after I have screw the two engine halves together =)[youtube=S1Lqdb5PPjU]
How come the piston have soooo much slack???
Thanks for very useful info.
I was going to install the crank today, as this has been in the freezer all night.
Do I need to heat the bearings as well, or will they just slip on? -
Excellent DarkMagic.
I guess it will fit my Polini kit then?
Ok, thanks for clearing that up :thumb
Whats the difference on these two decomp kits?
Which one will you recomend me to buy?http://www.jmpbparts.com/decompressiestift-veer-citta-ciao.html
http://www.jmpbparts.com/decompressieset-citta.html
:: Italjohn
