Italjohn reageerde in het onderwerp Italjohns Bravo 1984 (English) in het forum Projecten 10 jaar, 6 maanden geleden
Yes, if the finish is bad after I have cleaned them, I will powder coat them.
Is that bad or good?A pick of the clutch that was included with the wheels.
The new wheels 😀
Looks ok?
Italjohn reageerde in het onderwerp Dr Gonzo's 'GangGreen' in het forum Projecten 10 jaar, 6 maanden geleden
Better if you put the pick in the tread 😀
Thanks mate :thumb
Will this brake shoe fit?
And I forgot to install this earth point, so I had to take the engine out of the frame again :((
The wheels has arrived togheter with a broken headlight.
The good thing with the headligth is that it has a speedometer in it, and I was hoping to reuse that on my Bravo 😀
The wheels looks almost like new as well :thumb=)=)=) -
Italjohn reageerde in het onderwerp TK: Leo racing schalen in het forum Onderdelen aangeboden 10 jaar, 6 maanden geleden
Are these still availible for sale?
I migth need one of these:
I have sent you a PM, jeffrey :pest
To all of you, (if you like) please add me on facebook :bier
Italjohn reageerde in het onderwerp Italjohns Bravo 1984 (English) in het forum Projecten 10 jaar, 7 maanden geleden
Excellent picture of the side stand 😀
The decomp is the wrong one, as I need to see pictures of the Ciao one.
These wheels are now on its way to me 😀
They are SI wheels, and the front will not fit.
But I will try to modify the front brake, and have a slight hope to make it fit.
Had to pay €100 for them. Is that too much?
The SI side c…[Lees meer] -
Engine done 😀
Anyone have a picture of how this sidestand are mounted behind the side cover?
Italjohn reageerde in het onderwerp TK: CNC SHOP in het forum Onderdelen aangeboden 10 jaar, 7 maanden geleden
Looks fantastic :thumb
Italjohn reageerde in het onderwerp Polini Evolution engine in het forum General questions 10 jaar, 7 maanden geleden
Thanks for the feedback 🙂
I was just playing with the thoughts to buy a new Evolution engine, and manage to find one online 🙂
But if you say it’s no better then the Speed engine, I will stick to my Speed engine for now.But again, the Malossi engine looks better design with it’s huge reeds, compare to polini’s small ones.
Aha…. Thanks for the explination Martino.
I think I have got it now.PS: The tool is called Feelers in English :thumb
https://www.google.com/search?newwindow=1&biw=1679&bih=931&tbm=isch&sa=1&q=feelers+mm&oq=feelers+mm&gs_l=img.3…17946.19230.0.19580.3.3.0.0.0.0.95.270.3.3.0….0…1c.1.64.img..1.2.176.CqC0fhmLwSM -
Polini say you have to adjust the ignition timing????
How do you do that??
I have done that on my Vespa 125, but there is the igniton coils mounted on a plate the you can rotate.
Here the coils are in a pre determin place, and can’t be moved.
Edit: Do I have to make sure the points open 2,2mm before TDC? And thats it?
Italjohn reageerde in het onderwerp What is wrong with the clutch. in het forum General questions 10 jaar, 7 maanden geleden
The clutch shall not engage yet, it’s the starter “shoes” the must engage first.
Thats the two “shoes” inside the clutch.
If you have dismantle them, you probably have installed them the wrong way around.
I did the same on mine. Try to install them 180° and try again.Edit: From the video the shoes looks like they are installed the correct…[Lees meer]
Italjohn reageerde in het onderwerp Youtube link in het forum General questions 10 jaar, 7 maanden geleden
Fantastic, it worked 😀
Thanks :thumb
Will this head fit my Polini 46 cylinder, without any modification?
I don’t really like the Ciao head, and the decomp wont fit right on the Ciao head either.http://www.jmpbparts.com/cilinderkop-46mm-pinasco-citta-si.html
Or is this head from Malossi…[Lees meer]
Drilled hole for the capasitor 🙂
jeffreykruize :
At first, you are having a real nice bravo,
I also have a 1984 bravo and an 1982 bravo..
Made mine kawasaki green.Are you still interested in pictures of the decompression Valve?
That citta stand fits a bravo pretty well, but can be a little to short if you’re using longer rear shocks.
My bravo sometimes stands real… - Meer laden
:: Italjohn
