:: Will I need this washer?
Home Forums English General questions Will I need this washer?
  • #144216
    Coolvette
      When i got my SuperBravo the engine was in pieces so i need to ask a thing.´
      I have been adviced to put on a washer like this close to the flywheel when I put on the stock variator:
      I will put on a Malossi Multivario so my question is if I need this washer or if the spacer
      in the vario will do the thing, look at the red ring here:
      As I understand it the plastic spacer in the vario set, the one to the lower right on the picture
      is for keeping the speed down, if desired, correct?
      #146036
        No need for the spacer from your first photo.
        Also no need for low speed, so the other plastic ring could also be forgotten. 😉
        #146099
        Coolvette
          Martino :
          Thanks for the input.
          What is it indended for?
          I assume I must use the Malossi spacer in the red ring.
          The plasic spacer was out of the plan for me, no need to reduce speed in my opinion…8)
          #146072
          tnerual
            No. The red-ring spacer on the Malossi spacer is just a ring in order to restrict your variator! The only ring you will need is the other one, which you can see on the Malossi-picture!
            The ring that you have highlighted is just like a stock scooter-variator restrictor 😉
            Throw it away as far as you can 😉
            #145936
              No, it’s the other way around! Highlighted spacer is put directly onto your flywheel instead of the spacer which is used by the normal mono transmission with clutch. The ring on the bottom right corner is the restriction.
